Steering play/slack |
ronan |
Jan 13 2023, 05:21 PM
Newbie Group: Members Posts: 13 Joined: 23-December 22 From: Phoenix Member No.: 27,051 Region Association: Central California |
I just took apart the steering wheel on my 75 1.8, because there is way too much play from side to side and top to bottom. The steering wheel moves about a half inch in any direction. As I took it apart I gathered what seem to be disintegrated parts of an old bearing, or something else, I don’t know, the image is attached. From what I could tell everything looked normal (I am a new 914 owner and new to old cars in general though, so I don’t really know what to look for.) Has anyone had this problem before? What is the disintegrated stuff?
Attached thumbnail(s) |
Mikey914 |
Jan 16 2023, 12:01 PM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
There is a bearing in the column that I may or may not have, but it's possibly that, and this is the one toward the rack.
https://914rubber.com/steering-bearing-1 There are others but this is where I'd put my money Attached thumbnail(s) |
mmascari |
Feb 2 2023, 05:21 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
There is a bearing in the column that I may or may not have, but it's possibly that, and this is the one toward the rack. https://914rubber.com/steering-bearing-1 There are others but this is where I'd put my money How difficult is it to replace this? I have the same issue, the shaft moves and it is awful when driving and hitting bumps. Any direction from experts here on how to replace? |
Mikey914 |
Feb 8 2023, 11:43 AM
There is a bearing in the column that I may or may not have, but it's possibly that, and this is the one toward the rack. https://914rubber.com/steering-bearing-1 There are others but this is where I'd put my money How difficult is it to replace this? I have the same issue, the shaft moves and it is awful when driving and hitting bumps. Any direction from experts here on how to replace? For the bearing I showed you have to get under the fuel tank. It could be possible to get to it from underneath, but is probably easier to remove the tank. |
Lo-Fi Version | Time is now: 29th April 2024 - 01:03 AM |
