HP limit on standard 4 lug hub?, When to upgrade rear hub |
pgollender |
Jan 15 2023, 12:04 AM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
Converting 4 lug to 5 lug hubs. Eric Shea’s PMB website says redrilled conversion hubs good to 150 HP.
What about 325 HP ? Water cooled conversion is a never ending wicked game. |
sixnotfour |
Jan 15 2023, 01:28 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Carry Spare Parts
Superhawk996 |
Jan 15 2023, 06:49 AM
914 Guru Group: Members Posts: 5,814 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
The question is not one of how much horsepower but one of how much torque does the engine produce. Without AWD you will not be able to ground all the available torque the typical 300 HP engine can produce. You will spin tires before you shear the lugs or studs. Tire tractive force is your first “fuse”. Spinning tires keep other things from breaking. So you may say, let’s just use stickier tires like race rubber and a LSD to help reduce wheel spin (it will still occur). Wheel hubs still won’t be the limiting factor. CV joints will be a limitation before hubs. Axles / transmission / transmission output flanges will typically break before the hubs. After you “upgrade” those weak links, eventually, the rear rear suspension consoles will begin to fatigue and will tear off the chassis. See where this is going? Each “upgrade” just replaces one “fuse” with another. Each subsequent failure just keeps getting more expensive to fix. Have fun! |
Jan 15 2023, 07:23 AM
914-6 GT in waiting Group: Members Posts: 19,270 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
High hp conversions use 911 hubs and stubs to fit the cv’s that can take more torque. There are some 914 style cv’s that can hold more than stock. I believe renegade hybrid sells them.
Freezin 914 |
Jan 15 2023, 08:00 AM
Senior Member Group: Members Posts: 856 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
I could be wrong, but I think I have read 944 stuff can work as well for higher hp set ups.
mb911 |
Jan 15 2023, 08:17 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Well I popped a cv this summer that was brand new in a few thousand miles on it with my 2.4 s spec -6 engine
pgollender |
Jan 15 2023, 09:58 AM
pgollender |
Jan 15 2023, 10:05 AM
High hp conversions use 911 hubs and stubs to fit the cv’s that can take more torque. There are some 914 style cv’s that can hold more than stock. I believe renegade hybrid sells them. Do you have to run a different trailing arm bearing when using the 911 or 944 stub axles? And does it shift your wheel offset in or out? |
pgollender |
Jan 15 2023, 10:08 AM
(IMG:style_emoticons/default/agree.gif) The question is not one of how much horsepower but one of how much torque does the engine produce. Without AWD you will not be able to ground all the available torque the typical 300 HP engine can produce. You will spin tires before you shear the lugs or studs. Tire tractive force is your first “fuse”. Spinning tires keep other things from breaking. So you may say, let’s just use stickier tires like race rubber and a LSD to help reduce wheel spin (it will still occur). Wheel hubs still won’t be the limiting factor. CV joints will be a limitation before hubs. Axles / transmission / transmission output flanges will typically break before the hubs. After you “upgrade” those weak links, eventually, the rear rear suspension consoles will begin to fatigue and will tear off the chassis. See where this is going? Each “upgrade” just replaces one “fuse” with another. Each subsequent failure just keeps getting more expensive to fix. Have fun! Is there a rear console modification to help reinforce against the extra torque stresses? |
Montreal914 |
Jan 15 2023, 11:47 AM
Senior Member Group: Members Posts: 1,555 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
This is a good read. (IMG:style_emoticons/default/smile.gif)
http://www.914world.com/bbs2/index.php?showtopic=105728 |
pgollender |
Jan 15 2023, 12:06 PM
This is a good read. (IMG:style_emoticons/default/smile.gif) http://www.914world.com/bbs2/index.php?showtopic=105728 Thanks that definitely helps! |
mb911 |
Jan 15 2023, 01:16 PM
Jan 15 2023, 03:15 PM
Drag beetles with 4 lugs do wheelies.
the weak spot is not the number of lug bolts. rich |
Superhawk996 |
Jan 15 2023, 03:34 PM
Craigers17 |
Jan 15 2023, 07:05 PM
Senior Member Group: Members Posts: 733 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
If 4 don't hold it, 5 never woulda.
bkrantz |
Jan 15 2023, 08:50 PM
914 Guru Group: Members Posts: 7,761 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
So, up the hp and torque but leave the tires skinny?
Or always (ALWAYS) drive like your grandma (assuming gran was not a rally driver). |
pgollender |
Jan 16 2023, 10:29 AM
So, up the hp and torque but leave the tires skinny? Or always (ALWAYS) drive like your grandma (assuming gran was not a rally driver). Nah... what's the point of leaving all that power and torque in the engine bay? (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 10:30 AM |
