901 transmission cooler, Can it be done on the cheap? |
bondo |
Aug 10 2005, 01:15 PM
I have found small oil coolers with a fan for $100, but the electric pumps are expensive. My plan is to either find a cheap electric pump, or try and use the ring gear as a pump. The tricky part about the second option is it's hard to test. Can a cheap fuel pump be used to pump gear oil?
The intent here is to cool the oil and send it to the upper bearings so my 901 lasts behind a V8. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:50 PM |
