Reverse light switch location |
ronan |
Jan 18 2023, 02:44 PM
Newbie Group: Members Posts: 13 Joined: 23-December 22 From: Phoenix Member No.: 27,051 Region Association: Central California |
Where is the switch that turns off the reverse light? It’s the last thing that I need to have to get my car ready for restoring its salvage title. Do I need the reverse lights to pass the tier 3 examination in AZ? I have all other lights working but the reverse lights get no signal from whatever is supposed to turn them on, but they do work.
mjrrti |
Jan 18 2023, 02:51 PM
High Desert Member Group: Members Posts: 49 Joined: 4-February 14 From: Apple Valley, Ca Member No.: 16,959 Region Association: Southern California |
Where is the switch that turns off the reverse light? It’s the last thing that I need to have to get my car ready for restoring its salvage title. Do I need the reverse lights to pass the tier 3 examination in AZ? I have all other lights working but the reverse lights get no signal from whatever is supposed to turn them on, but they do work. It's on the transmission drivers side behind the axle, should have 2 wires going to it that come out of the harness that also goes to the starter. |
bdstone914 |
Jan 18 2023, 09:47 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Test it by connecting the two terminals with the ignition on. The back up lights should come on. If they do not check the wires for power. One should have power. The switch is about $80. It does not often go bad. It has a pin that pushes into it to close the circuit. The pin can get worn down. And check the bulbs and sockets in the light housings.
Lo-Fi Version | Time is now: 13th May 2024 - 02:32 PM |
