Shifter knob, Is it glued or just pressure fit? |
Deusexmachina77 |
Jan 20 2023, 07:56 AM
Member Group: Members Posts: 90 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
I'm replacing a wooden knob with an original. The problem is I powder-coated the stick shift. Now it's a bit thick. I'll need to sand it down so the knob will go on.
Does the OEM knob just fit with friction? Or is it glued in place? Maybe I screwed this one up? (IMG:style_emoticons/default/confused24.gif) Thanks, Victor |
TheCabinetmaker |
Jan 20 2023, 08:05 AM
It's held on with a "crush washer".
DRPHIL914 |
Jan 20 2023, 08:27 AM
except mine i had been glued by a DAPO, so you never know, but it should loosen and pull off with a bit of work, i just put a new one on recently as well. Phil |
Cairo94507 |
Jan 20 2023, 08:37 AM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Yeah, they can be problematic even when installed with a new crush washer. Those are available from 914 Rubber, Porsche and a host of others. Check the depth on the shifter and mark it with tape or something similar so once you do put the crush washer onto the shaft and then push the knob on you will know how far down it needs to go to be fully seated. Good luck- I do like the stock knob on our cars. (IMG:style_emoticons/default/beerchug.gif)
Deusexmachina77 |
Jan 20 2023, 09:21 AM
I think the crush washer is still inside. Does it look like a metal accordion wrapper/sleeve?
BillJ |
Jan 20 2023, 09:23 AM
Senior Member Group: Members Posts: 1,096 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Yep sure does. Pull it out and install with a new one.
Deusexmachina77 |
Jan 20 2023, 09:27 AM
emerygt350 |
Jan 20 2023, 11:45 AM
Advanced Member Group: Members Posts: 2,091 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
If you can't get it off, just go racing. It will pop right off at the most inopportune moment.
914e |
Jan 20 2023, 12:56 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
If you can't get it off, just go racing. It will pop right off at the most inopportune moment. (IMG:style_emoticons/default/lol-2.gif) |
Deusexmachina77 |
Jan 20 2023, 01:01 PM
If you can't get it off, just go racing. It will pop right off at the most inopportune moment. (IMG:style_emoticons/default/driving.gif) |
VegasRacer |
Jan 20 2023, 06:31 PM
ELVIRA Group: Benefactors Posts: 8,507 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
If you can't get it off, just go racing. It will pop right off at the most inopportune moment. @jat914 Attached image(s) |
bkrantz |
Jan 20 2023, 08:26 PM
914 Guru Group: Members Posts: 7,761 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) except mine i had been glued by a DAPO, so you never know, but it should loosen and pull off with a bit of work, i just put a new one on recently as well. Phil Mine, too. Fortunately the knob was a weird aftermarket, and I got it off with a bit of excess force. |
dirk2056 |
Jan 21 2023, 07:00 AM
Member Group: Members Posts: 93 Joined: 31-July 17 From: cincinnati/Eastside Member No.: 21,304 Region Association: Middle East |
If you can't get it off, just go racing. It will pop right off at the most inopportune moment. (IMG:style_emoticons/default/agree.gif) I put in a set screw to keep it tight, nice little spot for your finger to get a grip. |
GaroldShaffer |
Jan 21 2023, 03:32 PM
If you can't get it off, just go racing. It will pop right off at the most inopportune moment. @jat914 I met John many years ago when I would host the monthly 914 breakfast at the I Hop in Orland Park. John had the cleanest racecar I had ever seen. Told us that story and brought a photo album with aftermath pictures. YIKES! (IMG:style_emoticons/default/wacko.gif) The repair of that car was outstanding! |
Lo-Fi Version | Time is now: 14th May 2024 - 02:26 AM |
