Replacement 'panel' available? |
bossboy302 |
Jan 21 2023, 01:13 PM
Member Group: Members Posts: 73 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None |
I've removed the 4-cyl. mounting ears and found a bit of rust under the right side. Is there a replacement piece to repair this? Thx.
dr914@autoatlanta.com |
Jan 21 2023, 01:42 PM
914 Guru Group: Members Posts: 7,835 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
just used passenger side, we have new drivers side only. WE recently cut out a right one for a six conversion and if you cannot repair yours you can buy this one for 375.00
I've removed the 4-cyl. mounting ears and found a bit of rust under the right side. Is there a replacement piece to repair this? Thx. |
Steve |
Jan 22 2023, 07:57 AM
914 Guru Group: Members Posts: 5,579 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
If you’re referring to the 4 cylinder motor mounts mine also had rust behind it after removing it. We removed the rust which was also a layer of sheet metal. We ended up welding a scab plate over the area.
bossboy302 |
Jan 22 2023, 10:41 AM
just used passenger side, we have new drivers side only. WE recently cut out a right one for a six conversion and if you cannot repair yours you can buy this one for 375.00 I've removed the 4-cyl. mounting ears and found a bit of rust under the right side. Is there a replacement piece to repair this? Thx. Thanks. Yes, doing a 6 conversion. Eliminating the 4-cyl. mounting ears. The portion exposed behind it is what I'm wanting to fix. Surprised that there is a left side replacement piece when the right side seems the more problematic one. So no patch panel other than used? |
Luke M |
Jan 23 2023, 08:45 AM
Senior Member Group: Members Posts: 1,370 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
just used passenger side, we have new drivers side only. WE recently cut out a right one for a six conversion and if you cannot repair yours you can buy this one for 375.00 I've removed the 4-cyl. mounting ears and found a bit of rust under the right side. Is there a replacement piece to repair this? Thx. Thanks. Yes, doing a 6 conversion. Eliminating the 4-cyl. mounting ears. The portion exposed behind it is what I'm wanting to fix. Surprised that there is a left side replacement piece when the right side seems the more problematic one. So no patch panel other than used? Check with : https://maddogsmotorsports.com He made me some repair/reinforcement panels for my brothers 6 conv. |
Jan 24 2023, 02:41 PM
Unless you are doing a large area, it’s just a piece of 19 gauge bent over a piece of pipe to get the corner correct….then cut out as little as you can and weld in the new piece.
Lo-Fi Version | Time is now: 7th May 2024 - 04:24 AM |
