Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
schweet! is thing goin into a museum? ever gonna see a road? (IMG:style_emoticons/default/lol2.gif)
dsmeyer |
'73 914 2.0 ![]() ![]() Group: Members Posts: 134 Joined: 30-September 03 From: West Michigan Member No.: 1,210 ![]() |
You may want to consider painting parts of your brake rotors.
Otherwise they will start to rust the minute they see any water. I masked off where the pads contact the rotors and then sprayed on a high temp gray paint. Then I baked them in the oven per the intructions on the can. I also masked the area where the hub and the rotor mate to keep the surfaces true. This was done at least five years ago and it holds up fine for a street car. Attached image(s) ![]() |
dsmeyer |
Another picture of the painted rotor.
The strut is a RSR style raised spindle for a 16" wheel. (can be raised a little higher than for a 15" wheel) Notice the reshaped steering arm and the gussets for reinforcement where spindle welds to the shock tube. Attached image(s) ![]() |
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
mmm... big ass brakes!
dsmeyer |
QUOTE(kellzey @ Nov 8 2003, 11:40 AM) mmm... big ass brakes! Just stock '86 930/Turbo Look brakes. If I put brakes this heavy on my 914 it wouldn't go fast enough to need them... (IMG:style_emoticons/default/laugh.gif) |
Qarl |
Okay, my steering rack has been refurbished.
Bead blasted cross member Repacked steering rack with new moly grease Installed turbo tie rods Installed Bump Steer Kit (IMG:http://www.my914-6.com/DSCN2114.JPG) |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Your parts collection is nice!
You should build a car. M |
Qarl |
Thanks. I was thinking of doing that... maybe some day. (IMG:style_emoticons/default/MDB2.gif)
redshift |
We have bets on if you finish or not.
M |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Qarl |
Finish what? Collecting parts? I will never finish collecting them...
redshift |
lol Andrew!
Karl, you fail to see that you are under scrutiny by the central scrutinizer. (IMG:style_emoticons/default/laugh.gif) What's the time frame? Side bets! M |
Qarl |
Woohoo!!!! (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif)
(IMG:http://www.my914-6.com/wpe2.jpg) |
redshift |
lol
We are the only people who would have a kegger over a pile of wires like that.. WOOHOO! M |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
So, where did you find it?
cheers, Jeroen |
Qarl |
Miles,
I like how you sit in the shadows lurking... just waiting to reply to my posts... |
redshift |
Don't make me pull out the big red G.
M |
Qarl |
Long story on the harness...
I bought it about two years ago (before I even owned the current 914). Sold it about six months ago... (IMG:style_emoticons/default/headbang.gif) Recently re-acquired it! This is my old picture.. but it will be back in my posession soon! I still saved considerablly from what AA wanted for the only other one I could find! |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(kellzey @ Nov 12 2003, 08:08 PM) Installed Bump Steer Kit you may not need the bumpsteer kit with the reshaped steering arms on the RSR struts; they're both correcting for the same geometry/placement factor. my guess is the steering arm change will get you into the ballpark and you'll need at most a teeny shim under the rack to make it perfect. unless you're also relocating the rack in the tub, in which case i donno ... i'll contact you offlist about pricing and sourcing - i want those struts (possibly the 15" versions) on my 911 this winter ... BTW - fog light seals arrived just fine, thx. |
Qarl |
Those RSR struts aren't mine. They belong to another dsmeyer!!! I have regular Bilstein struts.
Lo-Fi Version | Time is now: 19th September 2025 - 02:16 PM |
