Basic Brake Maintenance Question, How to spread calipers |
Highland |
Jan 22 2023, 05:11 PM
Senior Member Group: Members Posts: 512 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Is there a proper way to spread the brake calipers when changing pads?
I assume the rears can be opened up with the adjustment screws. How does one spread the front calipers? Do I use something like a paint stick and make sure there is room in reservoir? Is it okay to push fluid backwards through the master cylinder? |
zoomCat |
Jan 22 2023, 06:14 PM
Member Group: Members Posts: 160 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
I use something made of wood to put pressure on the pistons, the rear also requires the use of the adjuster.
The factory manuals have the procedure, but they assume you have the factory tools. http://p914-6info.net/Manuals.htm |
BK911 |
Jan 22 2023, 07:05 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
I use the old brake pad.
Fits perfectly! Absolutely make sure there is room in the reservoir. If really old brake fluid, flush with new. |
fixer34 |
Jan 24 2023, 08:42 AM
Senior Member Group: Members Posts: 1,076 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Is there a proper way to spread the brake calipers when changing pads? I assume the rears can be opened up with the adjustment screws. How does one spread the front calipers? Do I use something like a paint stick and make sure there is room in reservoir? Is it okay to push fluid backwards through the master cylinder? Since I don't do it often, I use a large C-clamp to push the piston back into the caliper. Have to do each side separately. You do NOT want to use the adjusting screws on the rears to pull them back, they were not designed for that. Back them out a bit, push the pistons in until they stop, back the screws out more, repeat... A small piece of wood with a cut out hole for the screw protects it from the clamp. Yes, make sure the reservoir has room, brake fluid is not friendly to paint. Or open the bleed screw a little do a mini-flush. |
GregAmy |
Jan 24 2023, 09:01 AM
Advanced Member Group: Members Posts: 2,282 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
My most-favoritist tool I've ever purchased...
https://www.lislecorp.com/specialty-tools/r...ke-caliper-tool |
Jan 24 2023, 03:29 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
a big old flat non-sharp screw driver.
pry against the old pad, in between the pad and the rotor. If it does not move easily, you may have other issues that require more work, and removal of the caliper. Rich |
ClayPerrine |
Jan 25 2023, 07:01 AM
Life's been good to me so far..... Group: Admin Posts: 15,423 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
This is what I use....
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-1143-1674651711.1.jpg) It is a BIG pair. It also doubles as an oil filter wrench. |
VaccaRabite |
Jan 25 2023, 09:17 AM
En Garde! Group: Admin Posts: 13,432 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Since I do a lot of wood working, I have many of these. Good old wood clamps. They work really well as caliper adjusters as well. I have also used the same channel locks Clay uses to push the calipers back.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thdstatic.com-1435-1674659868.1.jpg) Zach |
Highland |
Jan 25 2023, 11:16 AM
[/quote]
Since I don't do it often, I use a large C-clamp to push the piston back into the caliper. Have to do each side separately. You do NOT want to use the adjusting screws on the rears to pull them back, they were not designed for that. Back them out a bit, push the pistons in until they stop, back the screws out more, repeat... A small piece of wood with a cut out hole for the screw protects it from the clamp. Yes, make sure the reservoir has room, brake fluid is not friendly to paint. Or open the bleed screw a little do a mini-flush. [/quote] So it is safe just to push the front pistons all the way back, but the rears have to be pushed to the adjustment screw limit a little bit at a time? Is it okay to just open the bleeder instead of "emptying" the reservoir? I have speed bleeders. |
VaccaRabite |
Jan 25 2023, 12:24 PM
So it is safe just to push the front pistons all the way back, but the rears have to be pushed to the adjustment screw limit a little bit at a time? Is it okay to just open the bleeder instead of "emptying" the reservoir? I have speed bleeders. One or two pumps with the speed bleeders will be enough unless your reservoir is full to the tippy top. Zach |
fixer34 |
Jan 25 2023, 06:37 PM
[quote name='Highland' date='Jan 25 2023, 11:16 AM' post='3053459']
[/quote] Since I don't do it often, I use a large C-clamp to push the piston back into the caliper. Have to do each side separately. You do NOT want to use the adjusting screws on the rears to pull them back, they were not designed for that. Back them out a bit, push the pistons in until they stop, back the screws out more, repeat... A small piece of wood with a cut out hole for the screw protects it from the clamp. Yes, make sure the reservoir has room, brake fluid is not friendly to paint. Or open the bleed screw a little do a mini-flush. [/quote] So it is safe just to push the front pistons all the way back, but the rears have to be pushed to the adjustment screw limit a little bit at a time? Is it okay to just open the bleeder instead of "emptying" the reservoir? I have speed bleeders. [/quote] Just so we are clear. When you push the pistons back into the caliper (pick your method), fluid will get pushed back into the reservoir. That is why you want to check that it is not to full. An alternative is to open the bleeder a little (speed bleeder or not doesn't really matter). Put a hose and bottle on it like you are bleeding the brakes and the fluid will go there instead of back to the reservoir. Once the pistons are fully compressed/retracted, tighten the bleeder. Repeat for as many calipers as you are doing. And yes, you need to back off the rear adjuster screws, push in the piston until it stops, back off the screw, etc. ** if you bleed the fluid out, make sure the reservoir is at least half full before pumping up the brakes. (you are doing new pads, maybe rotors?) Pump the pedal a couple times, then check the level and add as needed. On a different note, where in SD are you? I'll be out there in a month visiting my daughter & son-in-law for a long weekend. They are in the Claremont area. |
L-Jet914 |
Jan 25 2023, 07:22 PM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
You can use these on the rear brake pads and the front. I have a set for this style brake caliper. Place between the old pads and it allows both pistons to be pushed back into the bores. Best practice is to open a bleeder and push out the old fluid. Then refill reservoir after pumping brake pedal to seat pads.
FlacaProductions |
Jan 25 2023, 08:41 PM
Senior Member Group: Members Posts: 1,568 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@L-Jet914 - where did that come from?
PanelBilly |
Jan 25 2023, 10:20 PM
914 Guru Group: Members Posts: 5,799 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
This is what I use.... (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-1143-1674651711.1.jpg) It is a BIG pair. It also doubles as an oil filter wrench. I have the same one. Mine has some duct tape wrapped around the head to keep from scratching the surface |
76-914 |
Jan 26 2023, 11:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
This is what I use.... (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-1143-1674651711.1.jpg) It is a BIG pair. It also doubles as an oil filter wrench. I've have the same one. It must be 40 years old and not the Chinese knock off either. I've used it for so many things. Funny thing how often I end up using it. |
L-Jet914 |
Jan 26 2023, 05:37 PM
A number of different companies make them. I got mine off the local tool truck years ago. I know Lisle makes one and there are others that are exactly the same. |
Front yard mechanic |
Jan 26 2023, 06:07 PM
Senior Member Group: Members Posts: 1,157 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I use a dollar store turkey baster and take out the old fluid then use a crescent wrench handle to pry the old pads back. Works every time. Just don’t put it back in the kitchen drawer (IMG:style_emoticons/default/barf.gif)
Lo-Fi Version | Time is now: 2nd May 2024 - 03:21 AM |
