Yet Another Way, to Remove Broken Exhaust Studs from Aluminum Heads |
76-914 |
Jan 23 2023, 12:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Root_Werks |
Jan 23 2023, 01:51 PM
Village Idiot Group: Members Posts: 8,308 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Done both, welded material on and rotated out. Oil and ViceGrips, mostly works.
Had good luck with reverse drill bits. Start as small as possible and keep upsizing. Usually the friction heat and constant reverse torque turn out the broken stud. |
76-914 |
Jan 23 2023, 04:32 PM
Done both, welded material on and rotated out. Oil and ViceGrips, mostly works. Had good luck with reverse drill bits. Start as small as possible and keep upsizing. Usually the friction heat and constant reverse torque turn out the broken stud. Yes, me too. But I'd never tried to weld a broken stud that was recessed in the head. BTW, a 4" pipe wrench works much better than vice grips as it continually tightens its grip with additional force. IOW, it won't slip like vice grips. |
Lo-Fi Version | Time is now: 1st May 2024 - 11:54 AM |
