Yet Another Way, to Remove Broken Exhaust Studs from Aluminum Heads |
76-914 |
Jan 23 2023, 12:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
ClayPerrine |
Jan 24 2023, 06:26 AM
Life's been good to me so far..... Group: Admin Posts: 15,421 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If there is any of the stud sticking out, I use a oxyacetalene torch to weld a nut on the remainder of the stud. The heat from the torch helps to release the stud from the head.
For one that is broken off inside, I make a drill guide jig and use a left hand drill bit that is slightly smaller than the broken stud. For a 914 exhaust stud, I use the cast end off an early heat exchanger as a drill guide. Patience is the key. |
Lo-Fi Version | Time is now: 1st May 2024 - 02:01 PM |
