Yet Another Way, to Remove Broken Exhaust Studs from Aluminum Heads |
76-914 |
Jan 23 2023, 12:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
BillC |
Jan 25 2023, 01:05 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Aluminum has a larger coefficient of thermal expansion than steel. This makes it much harder to remove steel bolts from aluminum heads when cold, because the aluminum shrinks more in the cold and "clamps down" on the steel bolts.
But, if you first run the engine for a few minutes or use a propane torch to warm up the head, it will make removing the bolts much easier. |
Lo-Fi Version | Time is now: 1st May 2024 - 05:03 PM |
