Quick release hubs |
BillJ |
Jan 28 2023, 11:01 AM
Senior Member Group: Members Posts: 1,094 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
What are the racers using these days for quick release hubs? I have a setup with a dual pull pin setup but sometimes it binds and i want to refresh it. I have an original 6 so a different steering column and spline so want to see specifically for theat equipment.
Looking for excellent no fail designs where cost isnt the biggest factor. |
sixnotfour |
Jan 29 2023, 06:28 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Rothsport Racing. makes one based on the Porsche one they used... https://rothsport.com/collections/quick-rel...ering-hub-clear
BillJ |
Jan 29 2023, 07:52 PM
Will check it out!
BillJ |
Feb 18 2023, 04:24 PM
Ok so i found what i needed. Rennline makes a very short hub converter. Have it in hand and all is well. Just got.the old one off and have a question.
Should the steering shaft have any play? I am getting a good amount of deflection something like 1/2 inch if i had to guess. Is thhere a bushing i should insert before putting this back together? |
BillJ |
Feb 18 2023, 04:40 PM
Nevermind. Once the hub adapter went in the flange pressed into the bushing and it is now snug.
Attached thumbnail(s) |
sixnotfour |
Feb 19 2023, 02:10 PM
Huck271 |
Feb 19 2023, 05:09 PM
Newbie Group: Members Posts: 3 Joined: 19-February 23 From: The Woodlands, TX Member No.: 27,172 Region Association: Southwest Region |
BillJ |
Feb 19 2023, 11:22 PM
Using the stock location and rails so no the wheel sits a couple inches to the riight.
Lo-Fi Version | Time is now: 5th May 2024 - 11:49 AM |
