Throttle Cable Adjustment |
Tewfiks |
Jan 28 2023, 01:37 PM
Newbie Group: Members Posts: 5 Joined: 23-March 22 From: Florida Member No.: 26,416 Region Association: South East States |
Hello, my son and I are working on getting his 73 914 1.7 back on the road. It has Weber IDAs with a center pivot linkage set up. We installed a new throttle cable and I am currently having a heck of a time trying to get full throttle now. It seems that I may be binding somewhere near the pedal cluster.
Any thoughts or suggestions? Thanks |
NARP74 |
Jan 28 2023, 01:45 PM
Senior Member Group: Members Posts: 1,067 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Take the plates off at the front and rear of the tunnel and look for cable wrap or binding. Disconnect it at the engine and have a helper run the pedal and another feel the engine end of the cable, should be smooth.
mgphoto |
Jan 28 2023, 02:09 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
If you replaced the throttle and or the clutch cable it is common to twist the cables around each other near the pedals. Remove one of the cables and unwrap it from the other.
ChrisFoley |
Jan 29 2023, 06:10 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Failure of the throttle cable ferrule at the firewall can be a source of binding. Aftermarket cables often have poorly crimped ferrules in my experience. When the sheath pulls out of the ferrule the cable has to change direction without support.
Lo-Fi Version | Time is now: 18th May 2024 - 05:28 PM |
