BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,954 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
It's been well established that I am dumber than the average bear, but aren't the tie rod ends (on turbo tie rods) just supposed to unscrew off the tie rod? I'm not talking about getting the threaded end out of the control/pittman arm -- I've done that. I'm trying to replace the tie rod end. Heat, PB Blaster, but I can't seem to break it free. It's not easy getting leverage on the rod and the end at the same time, but I've put a fair amount of torque on there with no luck.
Any suggestions or thoughts? |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Aren't those reverse threads? It's been a long time since i last touched on of those.
(IMG:style_emoticons/default/idea.gif) |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,311 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
Lol. Yes. Yes they are. I remember that 42 minutes of my life.
BeatNavy |
Oh man, if that's the case, then I AM dumb.
But I did consider that at one point. I tried to go the other direction and it still wouldn't budge (although I didn't put as much effort into it then). Hmmm.... |
BeatNavy |
Nope, I can't get that tie rod end to move either direction on the rod. I don't know if the threads inside got boogered or if I did something on the install 5 or so years ago.
What are my options at this point? Do I unthread/remove the whole rod so I can at least get it on a vice or something? |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,041 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Nope, I can't get that tie rod end to move either direction on the rod. I don't know if the threads inside got boogered or if I did something on the install 5 or so years ago. What are my options at this point? Do I unthread/remove the whole rod so I can at least get it on a vice or something? @beatnavy Do you have the narrow wrench needed to fit the end of the tie rod? Have you tried a big hammer hit on the wrench to break it loose? |
BeatNavy |
Hey Bruce!
Yeah, I do have that special wrench. Just got done watching Ian's install video to remind me how this all went together. So how does one apply enough torque to get it to break free in this situation? The tie rod rotates freely in the rack, so you need to try to hold that still, and those little flat surfaces on the rod don't give much to hold onto. Not sure how I could do this with a hammer.... EDIT: or are you referring to removing the whole tie rod with the wrench and hammer? EDIT part II: wait, there's a narrow wrench for the end? I don't think I have that. I have the big one (36mm) that's used to secure the inner part to the rack. |
BeatNavy |
I took the tie rod off of the rack. PB Blaster, lots of heat, and I still can't get that thing to move. I clamped it as hard as I could in a vice and backing up with vice grips, but I can't get the rod to stay and the end to move. It's like it's welded to that thing.
I think my best bet at this point is to buy another tie rod (IMG:style_emoticons/default/sad.gif) |
SirAndy |
What am i missing here? I've always used two long wrenches and you move them towards each other to break the end lose.
Both parts should allow for a wrench (forget which sizes, the two are different if i recall) Can you post some pics of what you have? (IMG:style_emoticons/default/idea.gif) |
BeatNavy |
What am i missing here? I've always used two long wrenches and you move them towards each other to break the end lose. Both parts should allow for a wrench (forget which sizes, the two are different if i recall) Can you post some pics of what you have? (IMG:style_emoticons/default/idea.gif) I don't know, but I'm missing it, too, apparently. Yes, that's what I've been trying to do (I still think it's right hand threaded, but either direction it's not budging). The rod itself has a small flat surface that will fit a 12mm wrench although not that well. The tie rod end will take a 22mm wrench. Here's a pic: ![]() There was some surface rust on the threads from the 5 or so years I've been running these, but I still can't believe that's what's causing it not to budge. I said screw it and ordered a whole new tie rod / tie rod end assembly from the bird. |
BeatNavy |
Here's the tie rod off the rack. The ONLY thing I can think of is if I put something like red loctite in there during assembly. But I don't think I did that, nor do I think I am that dumb. And I heated that b**** up pretty good trying to break it free.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
More heat & more leverage.
SirAndy |
More heat & more leverage. (IMG:style_emoticons/default/blowtorch.gif) (IMG:style_emoticons/default/smash.gif) |
Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,901 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Vice & Pipe wrench (IMG:style_emoticons/default/confused24.gif)
BeatNavy |
Had the MAP torch out, but getting leverage is tough on that rod, even in a vise. Lots of heat, vise, biggest pipe wrench I have -- nada. Couldn't find anything to work as a cheater bar.
(IMG:style_emoticons/default/WTF.gif) though. It's not like it's a 40 year old rusty part. Been maybe 5 years, and maybe only one East Coast winter. The rest of the time it's been garaged in the winter. Thanks for the support, fellas, but I'm throwing in the towel on this one before I pull a groin. New tie rod shows up on Friday, I guess. |
SirAndy |
That is so weird, those threads should be moving freely since it's supposed to be the locking nut holding things in place.
(IMG:style_emoticons/default/blink.gif) |
mepstein |
That is so weird, those threads should be moving freely since it's supposed to be the locking nut holding things in place. (IMG:style_emoticons/default/blink.gif) Welcome to the east coast - (IMG:style_emoticons/default/laugh.gif) |
MDTerp |
Member ![]() ![]() Group: Members Posts: 109 Joined: 20-May 08 From: Maryland Member No.: 9,075 Region Association: MidAtlantic Region ![]() |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
(IMG:style_emoticons/default/WTF.gif) Wow. That is a head scratcher. Once that lock nut is loose, you can usually screw the tie rod end off by hand. Red loctite came to my mind too but I'm not even that dumb and I guarantee I'm dumber than you. I can't imagine it would be possible to cross thread those either.
mepstein |
(IMG:style_emoticons/default/WTF.gif) Wow. That is a head scratcher. Once that lock nut is loose, you can usually screw the tie rod end off by hand. Red loctite came to my mind too but I'm not even that dumb and I guarantee I'm dumber than you. I can't imagine it would be possible to cross thread those either. Red loctite should free up with heat. I use heat on the cylinder registers to free up head studs and a minute or two of head easily softens the loctite. |
Lo-Fi Version | Time is now: 15th July 2025 - 06:12 PM |
