Problem Removing Turbo Tie Rod End, Isn't it just supposed to unscrew? |
BeatNavy |
Jan 30 2023, 04:07 PM
It's been well established that I am dumber than the average bear, but aren't the tie rod ends (on turbo tie rods) just supposed to unscrew off the tie rod? I'm not talking about getting the threaded end out of the control/pittman arm -- I've done that. I'm trying to replace the tie rod end. Heat, PB Blaster, but I can't seem to break it free. It's not easy getting leverage on the rod and the end at the same time, but I've put a fair amount of torque on there with no luck.
Any suggestions or thoughts? |
BeatNavy |
Jan 31 2023, 08:22 AM
Nope, I can't get that tie rod end to move either direction on the rod. I don't know if the threads inside got boogered or if I did something on the install 5 or so years ago.
What are my options at this point? Do I unthread/remove the whole rod so I can at least get it on a vice or something? |
bdstone914 |
Jan 31 2023, 08:36 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Nope, I can't get that tie rod end to move either direction on the rod. I don't know if the threads inside got boogered or if I did something on the install 5 or so years ago. What are my options at this point? Do I unthread/remove the whole rod so I can at least get it on a vice or something? @beatnavy Do you have the narrow wrench needed to fit the end of the tie rod? Have you tried a big hammer hit on the wrench to break it loose? |
Lo-Fi Version | Time is now: 19th May 2024 - 07:09 PM |
