Problem Removing Turbo Tie Rod End, Isn't it just supposed to unscrew? |
BeatNavy |
Jan 30 2023, 04:07 PM
It's been well established that I am dumber than the average bear, but aren't the tie rod ends (on turbo tie rods) just supposed to unscrew off the tie rod? I'm not talking about getting the threaded end out of the control/pittman arm -- I've done that. I'm trying to replace the tie rod end. Heat, PB Blaster, but I can't seem to break it free. It's not easy getting leverage on the rod and the end at the same time, but I've put a fair amount of torque on there with no luck.
Any suggestions or thoughts? |
bbrock |
Jan 31 2023, 09:17 PM
(IMG:style_emoticons/default/WTF.gif) Wow. That is a head scratcher. Once that lock nut is loose, you can usually screw the tie rod end off by hand. Red loctite came to my mind too but I'm not even that dumb and I guarantee I'm dumber than you. I can't imagine it would be possible to cross thread those either.
mepstein |
Jan 31 2023, 11:25 PM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/WTF.gif) Wow. That is a head scratcher. Once that lock nut is loose, you can usually screw the tie rod end off by hand. Red loctite came to my mind too but I'm not even that dumb and I guarantee I'm dumber than you. I can't imagine it would be possible to cross thread those either. Red loctite should free up with heat. I use heat on the cylinder registers to free up head studs and a minute or two of head easily softens the loctite. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:44 PM |
