Problem Removing Turbo Tie Rod End, Isn't it just supposed to unscrew? |
BeatNavy |
Jan 30 2023, 04:07 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
It's been well established that I am dumber than the average bear, but aren't the tie rod ends (on turbo tie rods) just supposed to unscrew off the tie rod? I'm not talking about getting the threaded end out of the control/pittman arm -- I've done that. I'm trying to replace the tie rod end. Heat, PB Blaster, but I can't seem to break it free. It's not easy getting leverage on the rod and the end at the same time, but I've put a fair amount of torque on there with no luck.
Any suggestions or thoughts? |
mepstein |
Feb 5 2023, 10:07 AM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
One of the techs showed me his trick. He heats up the part and then uses a piece of paraffin wax. The wax wicks up the threads but unlike penetrating oils, doesn’t burn off easily. Pro techs don’t have all day (or days) to wait around for penetrating oil to work. This does it in minutes.
Superhawk996 |
Feb 5 2023, 11:04 AM
914 Guru Group: Members Posts: 5,834 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
One of the techs showed me his trick. He heats up the part and then uses a piece of paraffin wax. The wax wicks up the threads but unlike penetrating oils, doesn’t burn off easily. Pro techs don’t have all day (or days) to wait around for penetrating oil to work. This does it in minutes. (IMG:style_emoticons/default/agree.gif) Has its limitations but works extremely well especially good at preventing galling once it’s loosened. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:58 PM |
