> Does anyone have a Boxster flywheel., need some measurements
rick 918-S
post Jan 31 2023, 06:30 PM
Hey nice rack! -Celette
Wondering if it is the same diameter as the 914. Tooth count.
r_towle
post Jan 31 2023, 09:42 PM
Custom Member
QUOTE(rick 918-S @ Jan 31 2023, 07:30 PM) *
Carquip
Chris914n6
post Jan 31 2023, 11:09 PM
Jackstands are my life.
RockAuto usually has pics & specs.
I have one off a 996 auto. Don't know off hand if it's the same in that way.
rick 918-S
post Feb 1 2023, 06:11 AM
[quote name='Chris914n6' date='Jan 31 2023, 11:09 PM' post='3054828']
Sent you a PM (IMG:style_emoticons/default/shades.gif)
Chris914n6
post Feb 1 2023, 04:40 PM
Same teeth but more of them - 135. OD 287mm
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675291228.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675291228.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675291228.3.jpg)
I saw that the 928 has the starter on the motor side. I wonder if 928 stuff would be easier to make work?
ClayPerrine
post Feb 1 2023, 04:44 PM
A 928 flywheel, a Boxster spring center clutch disk, and a Boxster presssure plate. Machine a spacer to adapt the pressure plate to the flywheel.
That's what I did to make the Spec 944 turbo pressure plate work with the 964 flywheel.
Chris914n6
post Feb 1 2023, 10:43 PM
I think there is a disc & pp from an Audi that swaps, as the Boxster flywheel is dual mass/unsprung disc garbage.
rick 918-S
post Feb 2 2023, 05:58 AM
Thanks Chris. After looking a little I believe the custom Flywheel I have will work. I have to make a new adapter plate anyway. I will just need to bolt the starter on the engine side to the new adapter plate. The rest looks easy. The Boxster Transaxle appears to be very short.
r_towle
post Feb 2 2023, 10:22 AM
Custom Member
I’m interested in why you are doing this.
Also, measurements….length specifically.
Also, angle of axles.
Because….my next project is a tad longer and more powerful….so yah
What chu finding?
rick 918-S
post Feb 2 2023, 04:19 PM
QUOTE(r_towle @ Feb 2 2023, 10:22 AM) *
What chu finding?
Still several unanswered questions. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif)
r_towle
post Feb 5 2023, 02:19 PM
Custom Member
For reference:
1975, 2.0 liter
Firewall to transmission mating surface is 25.5 inches
Axles appear to be dead on 90 degree angle to transmission.
Car sitting on its wheels
- Lo-Fi Version Time is now: 5th July 2025 - 03:01 PM
