rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,011 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Wondering if it is the same diameter as the 914. Tooth count.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,490 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
RockAuto usually has pics & specs.
I have one off a 996 auto. Don't know off hand if it's the same in that way. |
rick 918-S |
[quote name='Chris914n6' date='Jan 31 2023, 11:09 PM' post='3054828']
RockAuto usually has pics & specs. I have one off a 996 auto. Don't know off hand if it's the same in that way. Sent you a PM (IMG:style_emoticons/default/shades.gif) |
Chris914n6 |
Same teeth but more of them - 135. OD 287mm
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675291228.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675291228.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675291228.3.jpg) I saw that the 928 has the starter on the motor side. I wonder if 928 stuff would be easier to make work? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,435 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
A 928 flywheel, a Boxster spring center clutch disk, and a Boxster presssure plate. Machine a spacer to adapt the pressure plate to the flywheel.
That's what I did to make the Spec 944 turbo pressure plate work with the 964 flywheel. |
Chris914n6 |
I think there is a disc & pp from an Audi that swaps, as the Boxster flywheel is dual mass/unsprung disc garbage.
rick 918-S |
Thanks Chris. After looking a little I believe the custom Flywheel I have will work. I have to make a new adapter plate anyway. I will just need to bolt the starter on the engine side to the new adapter plate. The rest looks easy. The Boxster Transaxle appears to be very short.
r_towle |
I’m interested in why you are doing this.
Also, measurements….length specifically. Also, angle of axles. Because….my next project is a tad longer and more powerful….so yah What chu finding? |
rick 918-S |
I’m interested in why you are doing this. Also, measurements….length specifically. Also, angle of axles. Because….my next project is a tad longer and more powerful….so yah What chu finding? Still several unanswered questions. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) |
r_towle |
For reference:
1975, 2.0 liter Firewall to transmission mating surface is 25.5 inches Axles appear to be dead on 90 degree angle to transmission. Car sitting on its wheels |
Lo-Fi Version | Time is now: 9th July 2025 - 03:32 AM |
