WTB: Hydraulic Clutch Kit/Parts for 901, Anyone have a hydraulic clutch system or parts? |
apexhound |
Jan 31 2023, 11:15 PM
Newbie Group: Members Posts: 5 Joined: 28-May 10 From: Los Angeles, California (west-side) Member No.: 11,771 Region Association: Southern California |
Does anyone have a hydraulic clutch kit (or parts) for a 901?
I’ve had enough of breaking/replacing cables (IMG:style_emoticons/default/driving.gif) / (IMG:style_emoticons/default/headbang.gif) , suggestions welcome! Thanks!!!! |
Superhawk996 |
Feb 1 2023, 12:06 PM
914 Guru Group: Members Posts: 5,760 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If you have cables that are repeatedly breaking, you most likely have a bad or missing ground strap between the body and the transmission.
When that ground is missing or too high of resistance, the clutch cable becomes the ground for the starter motor and drawing high current though the steel cable leads to it breaking. |
apexhound |
Feb 1 2023, 09:50 PM
If you have cables that are repeatedly breaking, you most likely have a bad or missing ground strap between the body and the transmission. When that ground is missing or too high of resistance, the clutch cable becomes the ground for the starter motor and drawing high current though the steel cable leads to it breaking. Thanks Hawk, Great/amazing suggestion - I’ll check the strap. I’ve had a lot of flex in that region of the car, bending exhaust pipes and muffler mounts! I’m running semi-rigid transaxle mounts with a stiffly sprung pressure plate and an aggressive driving style around the cones… the cable takes a lot of tension/cycling - I can imagine if it’s acting as a ground strap too, it’s bound to fail repeatedly! |
Lo-Fi Version | Time is now: 29th April 2024 - 06:44 AM |
