A few 914-6 cases |
A few 914-6 cases |
Unobtanium-inc |
Feb 1 2023, 04:52 PM
Advanced Member Group: Members Posts: 2,201 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Rob at DC just posted this, in case anyone is feeling lucky!
Attached image(s) |
gms |
Feb 5 2023, 10:33 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I sent this to Rob and he sent me a set of 80 mm heads without valves and some useless pistons pistons
Engine 1 914/6 air cleaner- melted Air cleaner snap cans – rusted thru Weber IDA carbs – broken air correction screw, seized throttle shafts Missing linkage cross bar, reverse lever and mounting brackets Cam shafts pitted Both cam towers – gouged cam bearing areas, second twisted Oil Cooler – crushed & does not hold pressure Heads (2.0 L1819d 911T) fly cut to 2.2L, inconsistent combustion chamber volumes, many studs missing 2.2L pistons and cylinders – water damaged, cylinders sanded Missing 2 rear engine transmission mounting studs m10x105mm (999.062.099.02) Engine 2 Only 1 K&N filter Zenith cards - seized throttle shafts, incorrect for 914/6 Alternator ring cracked (fan and alternator acceptable) Missing linkage cross bar, reverse lever and mounting brackets fiberglass engine shroud - broken mounting holes, Incorrect version Oil Cooler – AN? fitting welded to bottom 2.2L pistons and cylinders – mismatched set, water damaged, cylinders sanded Oil pump - Seized Missing flywheel Missing 2 rear transmission mounting studs m10x105mm (999.062.099.02) |
Lo-Fi Version | Time is now: 29th April 2024 - 10:26 AM |
