76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,740 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I'm in the process of collecting parts for my 5 lug conversion and wanted to ask if a 71.6mm Bore. 52mm Offset 5 x 130mm Bolt Pattern 17" x 7" wheel would fit. I believe they were on the 968's, maybe Boxters. TIA, Kent
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Should fit Kent. Mine are 17x7, 55 offset (I think they're same wheels you have on your orange car). You will need some spacers and longer studs. I have 15mm on mine. You can use the orange car wheels as test mules.
76-914 |
Should fit Kent. Mine are 17x7, 55 offset (I think they're same wheels you have on your orange car). You will need some spacers and longer studs. I have 15mm on mine. You can use the orange car wheels as test mules. The orange/red car has flares so I was doubtful but I'll check. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 15th July 2025 - 10:39 PM |
