> fuel pump relocation under steering rack pictures?
Geezer914
post Feb 4 2023, 08:57 AM
Geezer914
Anyone relocated the fuel pump and filter under the steering rack with to make it easier to change the fuel filter? Pictures? Thanks
Geezer914
post Feb 4 2023, 10:57 AM
Geezer914
Thanks for the pic.
Geezer914   fuel pump relocation under steering rack pictures?   Feb 4 2023, 08:57 AM
FlacaProductions   RE: fuel pump relocation under steering rack pictures?   Feb 4 2023, 09:48 AM
Geezer914   Thanks for the pic.   Feb 4 2023, 10:57 AM
Literati914   I’m planning the same .. any more pics out there...   Feb 4 2023, 11:11 AM
FlacaProductions   RE: fuel pump relocation under steering rack pictures?   Feb 4 2023, 11:37 AM
FlacaProductions   I know...I know....I don't like the blue crimp...   Feb 4 2023, 11:46 AM
mlindner   Geezer, not what your looking for but just to give...   Feb 4 2023, 12:13 PM
roundtwo   Geezer, not what your looking for but just to giv...   Feb 4 2023, 12:18 PM
mlindner   Roundtwo, yes filter always first. And I just cary...   Feb 4 2023, 12:26 PM
rhodyguy   I would not like having to remove the rack cover p...   Feb 4 2023, 12:26 PM
FlacaProductions   I would not like having to remove the rack cover ...   Feb 4 2023, 12:47 PM
windforfun   I would not like having to remove the rack cover ...   Feb 4 2023, 03:23 PM
Geezer914   Rhodyguy, if the pump or the filter craps out, tha...   Feb 4 2023, 02:53 PM
mlindner   Just pinch the fuel line for that.   Feb 4 2023, 04:44 PM
iankarr   The factory solution placed the pump in the tank w...   Feb 4 2023, 06:20 PM
JeffBowlsby   A concern with the front mounted pumps is that pre...   Feb 4 2023, 09:03 PM
JamesM   A concern with the front mounted pumps is that pr...   Feb 5 2023, 02:41 AM
wonkipop   A concern with the front mounted pumps is that p...   Feb 5 2023, 03:20 AM
barefoot   With a swap to stainless lines and the center tunn...   Feb 5 2023, 08:18 AM
wonkipop   With a swap to stainless lines and the center tun...   Feb 5 2023, 03:04 PM
ClayPerrine   a small thing to consider is that the 1.8 L jets...   Feb 5 2023, 05:15 PM
second wind   [quote name='wonkipop' post='3055756' date='Feb 5...   Feb 5 2023, 07:47 PM
wonkipop   [quote name='wonkipop' post='3055756' date='Feb 5...   Feb 6 2023, 01:25 AM
TX914   I have a 76 and I appreciate the stock pump/filter...   Feb 5 2023, 05:23 AM
rhodyguy   To even look at what might be the problem, even in...   Feb 5 2023, 01:52 PM
jhynesrockmtn   Mine is a 70. The PO had some hack relocate the f...   Feb 6 2023, 09:22 AM
partsguy22   Thanks Clay Here is the mount in question, I desi...   Feb 8 2023, 09:09 AM
partsguy22   This is it mocked up on a car As you can see it n...   Feb 8 2023, 09:15 AM
ClayPerrine   You could always put the pump on top of the bracke...   Feb 8 2023, 02:55 PM
jim_hoyland   Mounted mine in the front trunk; ball valve >Fi...   Feb 8 2023, 05:23 PM
- Lo-Fi Version Time is now: 10th July 2025 - 09:48 PM
