| Geezer914 |
Feb 4 2023, 08:57 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,156 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Anyone relocated the fuel pump and filter under the steering rack with to make it easier to change the fuel filter? Pictures? Thanks
| Literati914 |
Feb 4 2023, 11:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,174 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I’m planning the same .. any more pics out there? A few different angles would help clear the mind tbh (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/smoke.gif)
Geezer914 fuel pump relocation under steering rack pictures? Feb 4 2023, 08:57 AM
FlacaProductions RE: fuel pump relocation under steering rack pictures? Feb 4 2023, 09:48 AM
Geezer914 Thanks for the pic. Feb 4 2023, 10:57 AM
FlacaProductions RE: fuel pump relocation under steering rack pictures? Feb 4 2023, 11:37 AM
FlacaProductions I know...I know....I don't like the blue crimp... Feb 4 2023, 11:46 AM
mlindner Geezer, not what your looking for but just to give... Feb 4 2023, 12:13 PM
roundtwo
Geezer, not what your looking for but just to giv... Feb 4 2023, 12:18 PM
mlindner Roundtwo, yes filter always first. And I just cary... Feb 4 2023, 12:26 PM
rhodyguy I would not like having to remove the rack cover p... Feb 4 2023, 12:26 PM
FlacaProductions
I would not like having to remove the rack cover ... Feb 4 2023, 12:47 PM
windforfun
I would not like having to remove the rack cover ... Feb 4 2023, 03:23 PM
Geezer914 Rhodyguy, if the pump or the filter craps out, tha... Feb 4 2023, 02:53 PM
mlindner Just pinch the fuel line for that. Feb 4 2023, 04:44 PM
iankarr The factory solution placed the pump in the tank w... Feb 4 2023, 06:20 PM
JeffBowlsby A concern with the front mounted pumps is that pre... Feb 4 2023, 09:03 PM
JamesM
A concern with the front mounted pumps is that pr... Feb 5 2023, 02:41 AM
wonkipop
A concern with the front mounted pumps is that p... Feb 5 2023, 03:20 AM
barefoot With a swap to stainless lines and the center tunn... Feb 5 2023, 08:18 AM
wonkipop
With a swap to stainless lines and the center tun... Feb 5 2023, 03:04 PM
ClayPerrine
a small thing to consider is that the 1.8 L jets... Feb 5 2023, 05:15 PM
second wind
[quote name='wonkipop' post='3055756' date='Feb 5... Feb 5 2023, 07:47 PM
wonkipop
[quote name='wonkipop' post='3055756' date='Feb 5... Feb 6 2023, 01:25 AM
TX914 I have a 76 and I appreciate the stock pump/filter... Feb 5 2023, 05:23 AM
rhodyguy To even look at what might be the problem, even in... Feb 5 2023, 01:52 PM
jhynesrockmtn Mine is a 70. The PO had some hack relocate the f... Feb 6 2023, 09:22 AM
partsguy22 Thanks Clay
Here is the mount in question,
I desi... Feb 8 2023, 09:09 AM
partsguy22 This is it mocked up on a car
As you can see it n... Feb 8 2023, 09:15 AM
ClayPerrine You could always put the pump on top of the bracke... Feb 8 2023, 02:55 PM
jim_hoyland Mounted mine in the front trunk; ball valve >Fi... Feb 8 2023, 05:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th December 2025 - 10:15 PM |
