| Geezer914 |
Feb 4 2023, 08:57 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,187 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Anyone relocated the fuel pump and filter under the steering rack with to make it easier to change the fuel filter? Pictures? Thanks
| JeffBowlsby |
Feb 4 2023, 09:03 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,163 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
A concern with the front mounted pumps is that pressurized fuel is now routing through the cabin. I’m not comfortable with that.
| JamesM |
Feb 5 2023, 02:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,179 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
A concern with the front mounted pumps is that pressurized fuel is now routing through the cabin. I’m not comfortable with that. Don't own a 75-76 car then i guess. (IMG:style_emoticons/default/confused24.gif) With a swap to stainless lines and the center tunnel being a mostly enclosed metal tunnel with the few small openings under carpet I think ones chances of being directly exposed to gasoline from having the lines under pressure are very, very low. At its worst I dont see it as anymore dangerous than anything else about driving a very small 50+ year old car. Also I find it very preferable to vapor lock, especially on long trips. |
| wonkipop |
Feb 5 2023, 03:20 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,343 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
A concern with the front mounted pumps is that pressurized fuel is now routing through the cabin. I’m not comfortable with that. Don't own a 75-76 car then i guess. (IMG:style_emoticons/default/confused24.gif) With a swap to stainless lines and the center tunnel being a mostly enclosed metal tunnel with the few small openings under carpet I think ones chances of being directly exposed to gasoline from having the lines under pressure are very, very low. At its worst I dont see it as anymore dangerous than anything else about driving a very small 50+ year old car. Also I find it very preferable to vapor lock, especially on long trips. on the other hand stainless steel is brittle! i've done the metal lines, but i bent them up myself out of mild steel tube. just a thought. but you are right. something else in the 50 year old car is bound to do you malicious harm in a stack - before the fuel lines finish you off. (IMG:style_emoticons/default/sad.gif) |
Geezer914 fuel pump relocation under steering rack pictures? Feb 4 2023, 08:57 AM
FlacaProductions RE: fuel pump relocation under steering rack pictures? Feb 4 2023, 09:48 AM
Geezer914 Thanks for the pic. Feb 4 2023, 10:57 AM
Literati914 I’m planning the same .. any more pics out there... Feb 4 2023, 11:11 AM
FlacaProductions RE: fuel pump relocation under steering rack pictures? Feb 4 2023, 11:37 AM
FlacaProductions I know...I know....I don't like the blue crimp... Feb 4 2023, 11:46 AM
mlindner Geezer, not what your looking for but just to give... Feb 4 2023, 12:13 PM
roundtwo
Geezer, not what your looking for but just to giv... Feb 4 2023, 12:18 PM
mlindner Roundtwo, yes filter always first. And I just cary... Feb 4 2023, 12:26 PM
rhodyguy I would not like having to remove the rack cover p... Feb 4 2023, 12:26 PM
FlacaProductions
I would not like having to remove the rack cover ... Feb 4 2023, 12:47 PM
windforfun
I would not like having to remove the rack cover ... Feb 4 2023, 03:23 PM
Geezer914 Rhodyguy, if the pump or the filter craps out, tha... Feb 4 2023, 02:53 PM
mlindner Just pinch the fuel line for that. Feb 4 2023, 04:44 PM
iankarr The factory solution placed the pump in the tank w... Feb 4 2023, 06:20 PM
barefoot With a swap to stainless lines and the center tunn... Feb 5 2023, 08:18 AM
wonkipop
With a swap to stainless lines and the center tun... Feb 5 2023, 03:04 PM
ClayPerrine
a small thing to consider is that the 1.8 L jets... Feb 5 2023, 05:15 PM
second wind
[quote name='wonkipop' post='3055756' date='Feb 5... Feb 5 2023, 07:47 PM
wonkipop
[quote name='wonkipop' post='3055756' date='Feb 5... Feb 6 2023, 01:25 AM
TX914 I have a 76 and I appreciate the stock pump/filter... Feb 5 2023, 05:23 AM
rhodyguy To even look at what might be the problem, even in... Feb 5 2023, 01:52 PM
jhynesrockmtn Mine is a 70. The PO had some hack relocate the f... Feb 6 2023, 09:22 AM
partsguy22 Thanks Clay
Here is the mount in question,
I desi... Feb 8 2023, 09:09 AM
partsguy22 This is it mocked up on a car
As you can see it n... Feb 8 2023, 09:15 AM
ClayPerrine You could always put the pump on top of the bracke... Feb 8 2023, 02:55 PM
jim_hoyland Mounted mine in the front trunk; ball valve >Fi... Feb 8 2023, 05:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th January 2026 - 06:52 AM |
