| Geezer914 |
Feb 4 2023, 08:57 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,240 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Anyone relocated the fuel pump and filter under the steering rack with to make it easier to change the fuel filter? Pictures? Thanks
| JeffBowlsby |
Feb 4 2023, 09:03 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,199 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
A concern with the front mounted pumps is that pressurized fuel is now routing through the cabin. I’m not comfortable with that.
| JamesM |
Feb 5 2023, 02:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,183 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
A concern with the front mounted pumps is that pressurized fuel is now routing through the cabin. I’m not comfortable with that. Don't own a 75-76 car then i guess. (IMG:style_emoticons/default/confused24.gif) With a swap to stainless lines and the center tunnel being a mostly enclosed metal tunnel with the few small openings under carpet I think ones chances of being directly exposed to gasoline from having the lines under pressure are very, very low. At its worst I dont see it as anymore dangerous than anything else about driving a very small 50+ year old car. Also I find it very preferable to vapor lock, especially on long trips. |
| wonkipop |
Feb 5 2023, 03:20 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,445 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
A concern with the front mounted pumps is that pressurized fuel is now routing through the cabin. I’m not comfortable with that. Don't own a 75-76 car then i guess. (IMG:style_emoticons/default/confused24.gif) With a swap to stainless lines and the center tunnel being a mostly enclosed metal tunnel with the few small openings under carpet I think ones chances of being directly exposed to gasoline from having the lines under pressure are very, very low. At its worst I dont see it as anymore dangerous than anything else about driving a very small 50+ year old car. Also I find it very preferable to vapor lock, especially on long trips. on the other hand stainless steel is brittle! i've done the metal lines, but i bent them up myself out of mild steel tube. just a thought. but you are right. something else in the 50 year old car is bound to do you malicious harm in a stack - before the fuel lines finish you off. (IMG:style_emoticons/default/sad.gif) |
| barefoot |
Feb 5 2023, 08:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,484 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
With a swap to stainless lines and the center tunnel being a mostly enclosed metal tunnel with the few small openings under carpet I think ones chances of being directly exposed to gasoline from having the lines under pressure are very, very low. At its worst I dont see it as anymore dangerous than anything else about driving a very small 50+ year old car. Also I find it very preferable to vapor lock, especially on long trips. [/quote] on the other hand stainless steel is brittle! i've done the metal lines, but i bent them up myself out of mild steel tube. just a thought. but you are right. something else in the 50 year old car is bound to do you malicious harm in a stack - before the fuel lines finish you off. (IMG:style_emoticons/default/sad.gif) [/quote] I question your comment about SS being brittle, I've spent many years with SS in aircraft fuel systems and unless SS tubing is flexed to the point of fatigue failure it is not brittle. Fatigue failure would require many hundreds of flexes to near plastic bending to behave in a brittle fashion. |
Geezer914 fuel pump relocation under steering rack pictures? Feb 4 2023, 08:57 AM
FlacaProductions RE: fuel pump relocation under steering rack pictures? Feb 4 2023, 09:48 AM
Geezer914 Thanks for the pic. Feb 4 2023, 10:57 AM
Literati914 I’m planning the same .. any more pics out there... Feb 4 2023, 11:11 AM
FlacaProductions RE: fuel pump relocation under steering rack pictures? Feb 4 2023, 11:37 AM
FlacaProductions I know...I know....I don't like the blue crimp... Feb 4 2023, 11:46 AM
mlindner Geezer, not what your looking for but just to give... Feb 4 2023, 12:13 PM
roundtwo
Geezer, not what your looking for but just to giv... Feb 4 2023, 12:18 PM
mlindner Roundtwo, yes filter always first. And I just cary... Feb 4 2023, 12:26 PM
rhodyguy I would not like having to remove the rack cover p... Feb 4 2023, 12:26 PM
FlacaProductions
I would not like having to remove the rack cover ... Feb 4 2023, 12:47 PM
windforfun
I would not like having to remove the rack cover ... Feb 4 2023, 03:23 PM
Geezer914 Rhodyguy, if the pump or the filter craps out, tha... Feb 4 2023, 02:53 PM
mlindner Just pinch the fuel line for that. Feb 4 2023, 04:44 PM
iankarr The factory solution placed the pump in the tank w... Feb 4 2023, 06:20 PM
wonkipop
With a swap to stainless lines and the center tun... Feb 5 2023, 03:04 PM
ClayPerrine
a small thing to consider is that the 1.8 L jets... Feb 5 2023, 05:15 PM
second wind
[quote name='wonkipop' post='3055756' date='Feb 5... Feb 5 2023, 07:47 PM
wonkipop
[quote name='wonkipop' post='3055756' date='Feb 5... Feb 6 2023, 01:25 AM
TX914 I have a 76 and I appreciate the stock pump/filter... Feb 5 2023, 05:23 AM
rhodyguy To even look at what might be the problem, even in... Feb 5 2023, 01:52 PM
jhynesrockmtn Mine is a 70. The PO had some hack relocate the f... Feb 6 2023, 09:22 AM
partsguy22 Thanks Clay
Here is the mount in question,
I desi... Feb 8 2023, 09:09 AM
partsguy22 This is it mocked up on a car
As you can see it n... Feb 8 2023, 09:15 AM
ClayPerrine You could always put the pump on top of the bracke... Feb 8 2023, 02:55 PM
jim_hoyland Mounted mine in the front trunk; ball valve >Fi... Feb 8 2023, 05:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th March 2026 - 11:23 PM |
