> fuel pump relocation under steering rack pictures?
Geezer914
post Feb 4 2023, 08:57 AM
Geezer914
Anyone relocated the fuel pump and filter under the steering rack with to make it easier to change the fuel filter? Pictures? Thanks
rhodyguy
post Feb 5 2023, 01:52 PM
To even look at what might be the problem, even in your garage, you jack up the car, get under it, remove the pan retaining hardware, set the pan aside, investigate the problem, then (if you’re lucky) perform the repair, put everything back together and be on your way. This would be a major undertaking with a dead car south of a place like Drain OR. Best solution for moving the pump forward is sourcing a OEM cover/pump holder and mimicking the factory setup. Figure out how you intend to power the pump first. Planning on carrying a floor jack rather than trusting the factory jack? Not on level ground? You roll the dice going under the car. Maybe become a statistic.
Geezer914   fuel pump relocation under steering rack pictures?   Feb 4 2023, 08:57 AM
FlacaProductions   RE: fuel pump relocation under steering rack pictures?   Feb 4 2023, 09:48 AM
Geezer914   Thanks for the pic.   Feb 4 2023, 10:57 AM
Literati914   I’m planning the same .. any more pics out there...   Feb 4 2023, 11:11 AM
FlacaProductions   RE: fuel pump relocation under steering rack pictures?   Feb 4 2023, 11:37 AM
FlacaProductions   I know...I know....I don't like the blue crimp...   Feb 4 2023, 11:46 AM
mlindner   Geezer, not what your looking for but just to give...   Feb 4 2023, 12:13 PM
roundtwo   Geezer, not what your looking for but just to giv...   Feb 4 2023, 12:18 PM
mlindner   Roundtwo, yes filter always first. And I just cary...   Feb 4 2023, 12:26 PM
rhodyguy   I would not like having to remove the rack cover p...   Feb 4 2023, 12:26 PM
FlacaProductions   I would not like having to remove the rack cover ...   Feb 4 2023, 12:47 PM
windforfun   I would not like having to remove the rack cover ...   Feb 4 2023, 03:23 PM
Geezer914   Rhodyguy, if the pump or the filter craps out, tha...   Feb 4 2023, 02:53 PM
mlindner   Just pinch the fuel line for that.   Feb 4 2023, 04:44 PM
iankarr   The factory solution placed the pump in the tank w...   Feb 4 2023, 06:20 PM
JeffBowlsby   A concern with the front mounted pumps is that pre...   Feb 4 2023, 09:03 PM
JamesM   A concern with the front mounted pumps is that pr...   Feb 5 2023, 02:41 AM
wonkipop   A concern with the front mounted pumps is that p...   Feb 5 2023, 03:20 AM
barefoot   With a swap to stainless lines and the center tunn...   Feb 5 2023, 08:18 AM
wonkipop   With a swap to stainless lines and the center tun...   Feb 5 2023, 03:04 PM
ClayPerrine   a small thing to consider is that the 1.8 L jets...   Feb 5 2023, 05:15 PM
second wind   [quote name='wonkipop' post='3055756' date='Feb 5...   Feb 5 2023, 07:47 PM
wonkipop   [quote name='wonkipop' post='3055756' date='Feb 5...   Feb 6 2023, 01:25 AM
TX914   I have a 76 and I appreciate the stock pump/filter...   Feb 5 2023, 05:23 AM
rhodyguy   To even look at what might be the problem, even in...   Feb 5 2023, 01:52 PM
jhynesrockmtn   Mine is a 70. The PO had some hack relocate the f...   Feb 6 2023, 09:22 AM
partsguy22   Thanks Clay Here is the mount in question, I desi...   Feb 8 2023, 09:09 AM
partsguy22   This is it mocked up on a car As you can see it n...   Feb 8 2023, 09:15 AM
ClayPerrine   You could always put the pump on top of the bracke...   Feb 8 2023, 02:55 PM
jim_hoyland   Mounted mine in the front trunk; ball valve >Fi...   Feb 8 2023, 05:23 PM
- Lo-Fi Version Time is now: 8th December 2025 - 04:41 AM
