914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I'm trying to remove the nut that hold the shock in place. I need to replace the strut.
![]() I've tried heat, but maybe it wasn't hot enough. How hot do I get it? I'm using an 18" pipe wrench. It's the same one I put it on with. I changed the shocks about a year ago. It will not budge. It's hard to put leverage on when it's in the vise. I even hit the wrench with a dead blow hammer. It's currently soaking in penetrating oil. I tried using a drift and hammer to break it loose. Didn't budge. The next step would be to use a cheater bar on the wrench. However, I'm afraid I won't be able to hold it in the vice securely enough. Does anyone have any other ideas? Thanks! |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,197 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Measure the Bilstein sliding strut tube - my bet is that it is about 36mm or slightly smaller so that the tool can pass over the strut and engage the two slots.
914 RZ-1 |
Measure the Bilstein sliding strut tube - my bet is that it is about 36mm or slightly smaller so that the tool can pass over the strut and engage the two slots. It's 40mm. I would really like to know what the 36mm dimension in the tool description is referring to. |
Lo-Fi Version | Time is now: 3rd July 2025 - 12:14 AM |
