> Need help removing nut that holds shock in place, I've tried heat, a hammer and chisel...
914 RZ-1
post Feb 5 2023, 06:40 PM
Porsche Padawan
I'm trying to remove the nut that hold the shock in place. I need to replace the strut.
I've tried heat, but maybe it wasn't hot enough. How hot do I get it?
I'm using an 18" pipe wrench. It's the same one I put it on with. I changed the shocks about a year ago. It will not budge. It's hard to put leverage on when it's in the vise. I even hit the wrench with a dead blow hammer. It's currently soaking in penetrating oil.
I tried using a drift and hammer to break it loose. Didn't budge.
The next step would be to use a cheater bar on the wrench. However, I'm afraid I won't be able to hold it in the vice securely enough.
Does anyone have any other ideas?
Thanks!
930cabman
post Feb 8 2023, 05:52 AM
14" pipe wrench has worked just fine for me, maybe a bit of Mapp if necessary
914 RZ-1   Need help removing nut that holds shock in place   Feb 5 2023, 06:40 PM
r_towle   This https://www.edoperformance.com/products/bil.....   Feb 5 2023, 07:03 PM
Superhawk996   This https://www.edoperformance.com/products/bil....   Feb 5 2023, 07:19 PM
914 RZ-1   This https://www.edoperformance.com/products/bil....   Feb 5 2023, 08:11 PM
iankarr   Yep.   Feb 5 2023, 07:23 PM
r_towle   Google is your friend https://www.fvd.net/us-en/FV...   Feb 5 2023, 08:22 PM
914 RZ-1   Google is your friend https://www.fvd.net/us-en/F...   Feb 5 2023, 09:22 PM
Superhawk996   Measure the Bilstein sliding strut tube - my bet i...   Feb 5 2023, 10:43 PM
914 RZ-1   Measure the Bilstein sliding strut tube - my bet ...   Feb 6 2023, 10:58 PM
Superhawk996   Measure the Bilstein sliding strut tube - my bet...   Feb 6 2023, 11:12 PM
914 RZ-1   I have an email in to Bilstein. I'll let you a...   Feb 7 2023, 07:30 PM
Superhawk996   I think you’re on the right track - has to vary ...   Feb 7 2023, 08:02 PM
Van B   I can’t believe no one here knows the correct to...   Feb 7 2023, 11:49 PM
Superhawk996   I can’t believe no one here knows the correct t...   Feb 8 2023, 07:46 AM
930cabman   14" pipe wrench has worked just fine for me, ...   Feb 8 2023, 05:52 AM
Superhawk996   Best I’ve found - I think tool number is MS 08/6...   Feb 8 2023, 08:05 AM
Van B   There are basically two version floating out there...   Feb 8 2023, 11:39 AM
Superhawk996   I have enough 3/16" plate to make it myself ...   Feb 8 2023, 12:14 PM
mepstein   [quote name='Van B' post='3056474' date='Feb 8 20...   Feb 8 2023, 12:52 PM
Van B   I'm listening. That ball joint tool was the m...   Feb 8 2023, 01:05 PM
mepstein   I'm listening. That ball joint tool was the ...   Feb 8 2023, 01:16 PM
914 RZ-1   I bought both the tool from JimmyT and the wrench ...   Feb 13 2023, 10:16 PM
Van B   Thank you for posting that up! You just saved ...   Feb 13 2023, 10:19 PM
76-914   Got this adjustable gland nut wrench for $10....   Mar 13 2023, 08:54 AM
mepstein   Got this adjustable gland nut wrench for $10...   Mar 13 2023, 09:05 AM
76-914   Got this adjustable gland nut wrench for $1...   Mar 13 2023, 09:50 AM
VaccaRabite   Things change of course over time, but the school ...   Mar 13 2023, 11:47 AM
76-914   Things change of course over time, but the school...   Mar 13 2023, 12:12 PM
Van B   This thread came up via google so I thought it wor...   Jan 22 2024, 06:09 PM
Superhawk996   This thread came up via google so I thought it wo...   Jan 22 2024, 07:43 PM
technicalninja   Thanks for posting! Just ordered one. How can ...   Jan 22 2024, 06:18 PM
Superhawk996   How can they ship a $6 item for free??? Cau...   Jan 22 2024, 07:44 PM
Rufus   Corroded nuts & bolts? … penetrating oil? Iâ...   Jan 22 2024, 07:08 PM
Van B   Ha! Yeah, I got away with one on that purchase...   Jan 22 2024, 07:55 PM
- Lo-Fi Version Time is now: 19th January 2026 - 08:12 AM
