| 914 RZ-1 |
Feb 5 2023, 06:40 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm trying to remove the nut that hold the shock in place. I need to replace the strut.
I've tried heat, but maybe it wasn't hot enough. How hot do I get it? I'm using an 18" pipe wrench. It's the same one I put it on with. I changed the shocks about a year ago. It will not budge. It's hard to put leverage on when it's in the vise. I even hit the wrench with a dead blow hammer. It's currently soaking in penetrating oil. I tried using a drift and hammer to break it loose. Didn't budge. The next step would be to use a cheater bar on the wrench. However, I'm afraid I won't be able to hold it in the vice securely enough. Does anyone have any other ideas? Thanks! |
| Van B |
Feb 7 2023, 11:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
I can’t believe no one here knows the correct tool?
| Superhawk996 |
Feb 8 2023, 07:46 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,671 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I can’t believe no one here knows the correct tool? (IMG:style_emoticons/default/dry.gif) - would be funny if not so sad that suppliers can’t be bothered to actually state what diameter strut tube the Bilstein tool is for or to at least confirm it is for 914/911 sized struts. Pricing is all over the map too. Sierra Madre sells them which you would assume would be for 911/914 but they also have a little foot note that you may have to modify the tool - Really? Who wants to pay $50 for a simple stamped tool only to find out it doesn’t fit and needs to be modified when it appears the next guy is selling the same tool for $15. I also see Summit sells a Bilstein branded 60mm spanner wrench but that appears to be for adjusting coil over spring perches. Would probably work. I suspect Bistein will come to his aid with a proper tool number. |
914 RZ-1 Need help removing nut that holds shock in place Feb 5 2023, 06:40 PM
r_towle This
https://www.edoperformance.com/products/bil..... Feb 5 2023, 07:03 PM
Superhawk996
This
https://www.edoperformance.com/products/bil.... Feb 5 2023, 07:19 PM
914 RZ-1
This
https://www.edoperformance.com/products/bil.... Feb 5 2023, 08:11 PM
iankarr Yep. Feb 5 2023, 07:23 PM
r_towle Google is your friend
https://www.fvd.net/us-en/FV... Feb 5 2023, 08:22 PM
914 RZ-1
https://www.fvd.net/us-en/F... Feb 5 2023, 09:22 PM
Superhawk996 Measure the Bilstein sliding strut tube - my bet i... Feb 5 2023, 10:43 PM
914 RZ-1
Measure the Bilstein sliding strut tube - my bet ... Feb 6 2023, 10:58 PM
Superhawk996
Measure the Bilstein sliding strut tube - my bet... Feb 6 2023, 11:12 PM
914 RZ-1 I have an email in to Bilstein. I'll let you a... Feb 7 2023, 07:30 PM
Superhawk996 I think you’re on the right track - has to vary ... Feb 7 2023, 08:02 PM
930cabman 14" pipe wrench has worked just fine for me, ... Feb 8 2023, 05:52 AM
Superhawk996 Best I’ve found - I think tool number is MS 08/6... Feb 8 2023, 08:05 AM
Van B There are basically two version floating out there... Feb 8 2023, 11:39 AM
Superhawk996
I have enough 3/16" plate to make it myself ... Feb 8 2023, 12:14 PM
[quote name='Van B' post='3056474' date='Feb 8 20... Feb 8 2023, 12:52 PM
Van B I'm listening. That ball joint tool was the m... Feb 8 2023, 01:05 PM
I'm listening. That ball joint tool was the ... Feb 8 2023, 01:16 PM
914 RZ-1 I bought both the tool from JimmyT and the wrench ... Feb 13 2023, 10:16 PM
Van B Thank you for posting that up! You just saved ... Feb 13 2023, 10:19 PM
76-914 Got this adjustable gland nut wrench for $10.... Mar 13 2023, 08:54 AM
Got this adjustable gland nut wrench for $10... Mar 13 2023, 09:05 AM
76-914
Got this adjustable gland nut wrench for $1... Mar 13 2023, 09:50 AM
VaccaRabite Things change of course over time, but the school ... Mar 13 2023, 11:47 AM
76-914
Things change of course over time, but the school... Mar 13 2023, 12:12 PM
Van B This thread came up via google so I thought it wor... Jan 22 2024, 06:09 PM
Superhawk996
This thread came up via google so I thought it wo... Jan 22 2024, 07:43 PM
technicalninja Thanks for posting!
Just ordered one.
How can ... Jan 22 2024, 06:18 PM
Superhawk996
How can they ship a $6 item for free???
Cau... Jan 22 2024, 07:44 PM
Rufus Corroded nuts & bolts? … penetrating oil? Iâ... Jan 22 2024, 07:08 PM
Van B Ha! Yeah, I got away with one on that purchase... Jan 22 2024, 07:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th February 2026 - 04:11 PM |
