| 914 RZ-1 |
Feb 5 2023, 06:40 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm trying to remove the nut that hold the shock in place. I need to replace the strut.
I've tried heat, but maybe it wasn't hot enough. How hot do I get it? I'm using an 18" pipe wrench. It's the same one I put it on with. I changed the shocks about a year ago. It will not budge. It's hard to put leverage on when it's in the vise. I even hit the wrench with a dead blow hammer. It's currently soaking in penetrating oil. I tried using a drift and hammer to break it loose. Didn't budge. The next step would be to use a cheater bar on the wrench. However, I'm afraid I won't be able to hold it in the vice securely enough. Does anyone have any other ideas? Thanks! |
| VaccaRabite |
Mar 13 2023, 11:47 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,892 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Things change of course over time, but the school of thought on this was that you used a pipe wrench to take it off, and the special tool to reinstall.
The issue being that the special tool was not hardened enough and and a really stuck on nut would wipe it out. The pipe wrench will put marks in the nut, but it will get the damned thing off. I just have a big assed pipe wrench from when I needed to do it. Zach |
914 RZ-1 Need help removing nut that holds shock in place Feb 5 2023, 06:40 PM
r_towle This
https://www.edoperformance.com/products/bil..... Feb 5 2023, 07:03 PM
Superhawk996
This
https://www.edoperformance.com/products/bil.... Feb 5 2023, 07:19 PM
914 RZ-1
This
https://www.edoperformance.com/products/bil.... Feb 5 2023, 08:11 PM
iankarr Yep. Feb 5 2023, 07:23 PM
r_towle Google is your friend
https://www.fvd.net/us-en/FV... Feb 5 2023, 08:22 PM
914 RZ-1
https://www.fvd.net/us-en/F... Feb 5 2023, 09:22 PM
Superhawk996 Measure the Bilstein sliding strut tube - my bet i... Feb 5 2023, 10:43 PM
914 RZ-1
Measure the Bilstein sliding strut tube - my bet ... Feb 6 2023, 10:58 PM
Superhawk996
Measure the Bilstein sliding strut tube - my bet... Feb 6 2023, 11:12 PM
914 RZ-1 I have an email in to Bilstein. I'll let you a... Feb 7 2023, 07:30 PM
Superhawk996 I think you’re on the right track - has to vary ... Feb 7 2023, 08:02 PM
Van B I can’t believe no one here knows the correct to... Feb 7 2023, 11:49 PM
Superhawk996
I can’t believe no one here knows the correct t... Feb 8 2023, 07:46 AM
930cabman 14" pipe wrench has worked just fine for me, ... Feb 8 2023, 05:52 AM
Superhawk996 Best I’ve found - I think tool number is MS 08/6... Feb 8 2023, 08:05 AM
Van B There are basically two version floating out there... Feb 8 2023, 11:39 AM
Superhawk996
I have enough 3/16" plate to make it myself ... Feb 8 2023, 12:14 PM
[quote name='Van B' post='3056474' date='Feb 8 20... Feb 8 2023, 12:52 PM
Van B I'm listening. That ball joint tool was the m... Feb 8 2023, 01:05 PM
I'm listening. That ball joint tool was the ... Feb 8 2023, 01:16 PM
914 RZ-1 I bought both the tool from JimmyT and the wrench ... Feb 13 2023, 10:16 PM
Van B Thank you for posting that up! You just saved ... Feb 13 2023, 10:19 PM
76-914 Got this adjustable gland nut wrench for $10.... Mar 13 2023, 08:54 AM
Got this adjustable gland nut wrench for $10... Mar 13 2023, 09:05 AM
76-914
Got this adjustable gland nut wrench for $1... Mar 13 2023, 09:50 AM
76-914
Things change of course over time, but the school... Mar 13 2023, 12:12 PM
Van B This thread came up via google so I thought it wor... Jan 22 2024, 06:09 PM
Superhawk996
This thread came up via google so I thought it wo... Jan 22 2024, 07:43 PM
technicalninja Thanks for posting!
Just ordered one.
How can ... Jan 22 2024, 06:18 PM
Superhawk996
How can they ship a $6 item for free???
Cau... Jan 22 2024, 07:44 PM
Rufus Corroded nuts & bolts? … penetrating oil? Iâ... Jan 22 2024, 07:08 PM
Van B Ha! Yeah, I got away with one on that purchase... Jan 22 2024, 07:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th July 2026 - 04:09 AM |
