> 2056 rebuild part THREE, GOT Data? Log works 3
rfinegan
post Feb 6 2023, 07:38 AM
Post #21
Here is a link to part one:
http://www.914world.com/bbs2/index.php?sho...117&hl=2056
I decide my t1 oil pump in my 2056 was doing me no favors with a smaller than ideal OD.
I still had the T4 oil pump from the 2.0 that was doing its job when I had a cam thrust bearing fail /knock, so I decided to pull it a part for inspection.
I will perform some measurements and get it cleaned up, if it turns out to be in good shape.
The pics look like a great core.
rfinegan   2056 rebuild part THREE   Feb 6 2023, 07:38 AM
Superhawk996   Agree - looks like a pretty good core. Pin the ...   Feb 6 2023, 07:50 AM
rfinegan   Great link, this should be a sticky if its not the...   Feb 6 2023, 08:04 AM
rfinegan   Here are come pics of case split and inspections   Feb 6 2023, 08:33 AM
rfinegan   another of the saddle and low pin locator   Feb 6 2023, 08:35 AM
rfinegan   rear thrust again   Feb 6 2023, 08:37 AM
rfinegan   and a video : dJ_iKZHldNk   Feb 6 2023, 08:44 AM
DRPHIL914   so what are your impressions of your observations ...   Feb 6 2023, 09:09 AM
rfinegan   Phil, This build and the last build had a total o...   Feb 6 2023, 09:42 AM
DRPHIL914   Phil, This build and the last build had a total ...   Feb 6 2023, 10:13 AM
rfinegan   Here is the worst of the intake guide #1. The exha...   Feb 6 2023, 09:45 AM
914sgofast2   Here is the worst of the intake guide #1. The exh...   Feb 6 2023, 12:36 PM
rfinegan   I have a new local shop add new intake guides and ...   Feb 6 2023, 09:48 AM
rfinegan   My summary of this build: 1) OIL pressure problems...   Feb 6 2023, 09:53 AM
Jack Standz   Crankshaft float s/b .004" plus or minus .001...   Feb 6 2023, 11:31 AM
rfinegan   check in without seal and again once the seal is i...   Feb 6 2023, 11:32 AM
Geezer914   Rear main seal tool, use a block of wood. Go easy...   Feb 6 2023, 02:56 PM
porschetub   Rear main seal tool, use a block of wood. Go eas...   Feb 7 2023, 03:23 PM
rfinegan   GREAT info on the rear main seal. ..with mods ht...   Feb 9 2023, 01:27 PM
rfinegan   Happy day for a change in the garage A world memb...   Feb 14 2023, 03:16 PM
914sgofast2   From your picture of the engine case mounted in th...   Feb 14 2023, 03:51 PM
rfinegan   I linked to the Raby live stream in post 19 Now th...   Feb 14 2023, 04:38 PM
NARP74   What were your thoughts on the wrong oil? Why did...   Feb 14 2023, 03:46 PM
rfinegan   I was thinking the VR1 20W50 was not the best oil ...   Feb 14 2023, 04:32 PM
NARP74   I was thinking the ZR 20W50 was not the best oil ...   Feb 14 2023, 04:38 PM
rfinegan   Trying to keep the motivation up on this holiday w...   Feb 19 2023, 01:32 PM
rfinegan   RE: 2056 rebuild part THREE   Feb 19 2023, 01:38 PM
barefoot   You keep your tools in the dark ??   Feb 19 2023, 05:47 PM
rfinegan   Old trick of the trade...no one asks to borrow any...   Feb 19 2023, 06:45 PM
r_towle   This will be the third build? Curious about break...   Feb 19 2023, 07:21 PM
rfinegan   Rich, Yep this is # 3 and the $1000 dollar q...   Feb 20 2023, 07:04 AM
rfinegan   Heads are repaired with new intake guides and 3 an...   Feb 21 2023, 04:03 PM
Cairo94507   I have my fingers and toes crossed this motor purr...   Feb 22 2023, 08:35 AM
rfinegan   I will be having a sale on engine parts it it does...   Feb 22 2023, 09:36 AM
rfinegan   I did some detailed measuring on the con rod journ...   Mar 4 2023, 08:24 AM
914rrr   Lots of great info on this thread! Good luck...   Mar 4 2023, 08:59 AM
rfinegan   It took a while but I finally got a set of NOS KS/...   Mar 27 2023, 05:24 AM
rfinegan   Thanks to the generosity of a Kerry, world member...   Mar 27 2023, 05:29 AM
rfinegan   :headbanger:   Mar 27 2023, 06:26 AM
rfinegan   Add a VDO HEAD TEMP thermocouple under the #3 spar...   Mar 28 2023, 05:54 PM
VaccaRabite   Unless things have changed, the VDO head temp gaug...   Mar 29 2023, 06:09 AM
rfinegan   This way the sensor stays in place when servicing ...   Mar 29 2023, 07:18 AM
rfinegan   Never opposed to OE parts if you can get them....   Mar 29 2023, 11:11 AM
rfinegan   I may be CRAZY, but got a set of ML Cam bearings n...   Apr 7 2023, 11:06 AM
rfinegan   NEW KS 2.0 rod bearing are HERE....   Apr 7 2023, 11:07 AM
rfinegan   Just got a new tube of valve lapping paste...The o...   Jun 21 2023, 04:50 PM
porschetub   Just got a new tube of valve lapping paste...The ...   Jun 21 2023, 05:36 PM
rfinegan   KTM 125 top end upgrade in the background.....whil...   Jun 21 2023, 05:00 PM
r_towle   You keep learning all sorts of fun things!   Jun 21 2023, 05:33 PM
rfinegan   heads are disassembled cleaned and lubed and back ...   Jul 9 2023, 03:48 PM
rfinegan   The windage tray had the same old seals, so a new ...   Jul 9 2023, 03:56 PM
rfinegan   vintage bearings too   Jul 9 2023, 03:57 PM
rfinegan   here is a video of the camshaft end play WpUDEaOW...   Jul 9 2023, 03:59 PM
rfinegan   Measured the case, bearings and crank journals as ...   Jul 9 2023, 04:06 PM
Cairo94507   :popcorn: Can't wait for this to be fired-up. ...   Jul 9 2023, 05:49 PM
rfinegan   :popcorn: Can't wait for this to be fired-up....   Jul 10 2023, 06:57 AM
DRPHIL914   :popcorn: Can't wait for this to be fired-up...   Jul 17 2023, 06:14 AM
rfinegan   Lapping the heads can only be a good thing, and yo...   Jul 17 2023, 07:30 AM
DRPHIL914   Lapping the heads can only be a good thing, and y...   Jul 17 2023, 07:57 AM
rfinegan   I did pin the shaft on the T4 oil pump. Drilled an...   Jul 10 2023, 06:02 AM
rfinegan   Playing with a thermal dispersion paint from Cerak...   Jul 17 2023, 05:30 AM
rfinegan   heads   Jul 17 2023, 06:14 AM
rfinegan   I updated ALL my videos on You tube for Robert Fin...   Jul 17 2023, 08:37 AM
rfinegan   Tonight I cleaned the carbon off the piston tops a...   Jul 19 2023, 04:28 PM
rfinegan   another   Jul 19 2023, 04:29 PM
rfinegan   one more   Jul 19 2023, 04:29 PM
BeatNavy   Looking really good, Robert! :thumbsup:   Jul 19 2023, 05:14 PM
rfinegan   Thanks Rob, Thanks for positive feed back, it is...   Jul 20 2023, 08:33 AM
r_towle   Thank you for doing such a great job documenting b...   Jul 20 2023, 07:58 PM
r_towle   TLDR, Did you use that paint on everything? Cool...   Jul 20 2023, 08:00 PM
rfinegan   TLDR, Did you use that paint on everything? I ...   Jul 21 2023, 05:35 AM
Cairo94507   :popcorn: :beer3:   Jul 21 2023, 06:18 AM
rfinegan   plan for the weekend... 1)Home made Jet Doctors fo...   Jul 21 2023, 07:10 AM
rfinegan   Darn, the engine yoke got me again. its touching t...   Jul 23 2023, 07:30 AM
rfinegan   DIY: Jet Doctor for idle jets or just by them fro...   Jul 23 2023, 11:11 AM
rfinegan   oil primer in progress...   Jul 23 2023, 02:30 PM
rfinegan   engine update..stubs and tins next...   Jul 23 2023, 02:34 PM
rfinegan   engine yoke mod...#3 cylinder   Jul 23 2023, 02:36 PM
rfinegan   cylinders hitting the the yoke frame   Jul 23 2023, 03:25 PM
rfinegan   Today I installer the blower housing, blower front...   Jul 24 2023, 04:24 PM
rfinegan   another pic of the bottom   Jul 24 2023, 04:27 PM
porschetub   another pic of the bottom looking great,thermost...   Jul 28 2023, 08:32 PM
rfinegan   Installed and torqued Clutch, Pressure plate and f...   Jul 24 2023, 04:29 PM
rfinegan   Today I recondition push rod tubs to remove dents ...   Jul 28 2023, 05:48 PM
rfinegan   added right tins and distributor   Jul 28 2023, 05:52 PM
barefoot   added right tins and distributor Make sure yo...   Jul 29 2023, 06:54 AM
rfinegan   I may have to try to fit an aftermarket thermostat...   Jul 29 2023, 06:38 AM
rfinegan   Good eye. Not wanting to pull the alternator/cover...   Jul 31 2023, 05:45 AM
rfinegan   Add a PMO fuel regulator (purchased in the classif...   Aug 6 2023, 01:53 PM
rfinegan   install pics..all done under the car. including Wi...   Aug 6 2023, 04:23 PM
rfinegan   another view of the Tangerine clutch mount Gen 1 ...   Aug 6 2023, 04:26 PM
rfinegan   Lets see how I did... I add 5 gals of 93 octane t...   Aug 13 2023, 09:30 AM
rfinegan   SO... I think I spiked the module doing power bal...   Aug 13 2023, 10:00 AM
BeatNavy   Nice job, Robert! :Qarl:   Aug 13 2023, 11:15 AM
rjames   Excellent!! :beer1:   Aug 13 2023, 02:27 PM
Cairo94507   Congratulations! She sounds good. :beer2:   Aug 13 2023, 03:33 PM
technicalninja   Sounds healthy! Pretty balanced for a first st...   Aug 13 2023, 03:55 PM
rfinegan   I add a new Malory Module to my ignition system H...   Aug 16 2023, 10:45 AM
rfinegan   30 min or so run time so I better get some Fresh o...   Aug 16 2023, 10:47 AM
technicalninja   On a first run in like you just did I clean the pi...   Aug 16 2023, 03:28 PM
- Lo-Fi Version Time is now: 14th July 2025 - 01:58 AM
