Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
billh1963 |
Feb 6 2023, 04:18 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Probably a stupid question but are Holley sniper and similar systems too big for the Type IV? With 4 bbl intake "manifolds" available seems like that could work (if not too big).
mihai914 |
Feb 7 2023, 07:46 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Probably a stupid question but are Holley sniper and similar systems too big for the Type IV? With 4 bbl intake "manifolds" available seems like that could work (if not too big). It's a valid question and I think the main issue with the Sniper EFI systems is that you lose the port injection and revert to a throttle body injection which will cause fuel atomization problems due to the long runners. The 4 bbl might be too big but they do offer a 1bbl that may or may not fit in place of the throttle body on a 2.0 setup. https://www.holley.com/products/fuel_system...l/parts/550-552 |
Superhawk996 |
Feb 7 2023, 08:58 AM
914 Guru Group: Members Posts: 5,769 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Probably a stupid question but are Holley sniper and similar systems too big for the Type IV? With 4 bbl intake "manifolds" available seems like that could work (if not too big). It's a valid question and I think the main issue with the Sniper EFI systems is that you lose the port injection and revert to a throttle body injection which will cause fuel atomization problems due to the long runners. The 4 bbl might be too big but they do offer a 1bbl that may or may not fit in place of the throttle body on a 2.0 setup. Throttle body injection (TBI) is the worst version of fuel injection. Not even a step up from carbs in my opinion. You get the complexity of fuel injection with all the disadvantages of carbs. As mentioned above - atomization, fuel drop out in the runners are major issues. You also don’t have control over fuel distribution. Fuel simply goes where it goes. Some cylinders will get more fuel than others. Then there are mass flow effects. Having the fuel injected that far away from the cylinder creates a large time delay between the time the fuel is injected and when it gets to the cylinder. That delay affects throttle response negatively. Not much of a problem on lumbering V8’s. Not good for high reving small displacement engine’s that change engine speed more quickly. VW & Porsche (and most other European OEMs) had the common sense to avoid TBI and go straight to port injection. The domestics were too embedded in the past and didn’t want to retool new manifolds, wiring, etc. and went for the cheap solution of TBI. When emissions could no longer be met with TBI, they were forced to go to port injection. Don’t ignore history. |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:13 PM |
