Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
rbzymek |
Feb 7 2023, 02:01 PM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
I worked at Ford in the engine controls department during the Carb/TBI/MAP Port Injection/Mas air Meter Port Injection time frame. Port injection is far superior to TBI for the reasons given by superhawk996. For a 2056 street car you can't beat an L-Jet system with a Vanagon throttle body. It uses a vane meter to measure airflow and can easily be adjusted to run slightly rich with an AFR meter.
Lo-Fi Version | Time is now: 3rd May 2024 - 12:29 AM |
