Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
Jack Standz |
Feb 7 2023, 06:45 PM
Member Group: Members Posts: 272 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Well, I don't know how Edelbrock got it to work (or addressed the safety issues discussed above), but back in 2015 they put together this manifold that can use two DBW throttle bodies:
https://www.edelbrock.com/cross-ram-ls3-int...ifold-7141.html Was seriously looking at getting one for an LS4 motor eventually going into a Fiero, but they don't offer it for the cathedral heads (and it's pricey, although less now than when introduced). So, it's not a type iv motor, but could be considered a proof of concept for using dual DBW throttle bodies on one motor. And of course you can always fool around with trying to use mechanical throttle bodies and mechanical linkage if the DBW ones give you heartburn. |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:41 AM |
