Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
bkrantz |
Feb 7 2023, 09:12 PM
914 Guru Group: Members Posts: 7,742 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I have the Dub Shop kit on my 2056. As delivered it was easy to install and set up, and it started and idled on the first attempt with the default Type 4 tune file Mario included. After one dyno session I consider the tune 90-95% complete. I hope to get the remaining 5% this summer as I learn how to tweak the Megasquirt settings.
rgolia |
Feb 8 2023, 11:53 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
I have the Dub Shop kit on my 2056. As delivered it was easy to install and set up, and it started and idled on the first attempt with the default Type 4 tune file Mario included. After one dyno session I consider the tune 90-95% complete. I hope to get the remaining 5% this summer as I learn how to tweak the Megasquirt settings. Did you have carbs prior to installing the dub shop kit? If so, what are the benefits. That is not a cheap kit, but I am seriously considering it. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:30 AM |
