Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
GregAmy |
Feb 6 2023, 09:30 AM
Advanced Member Group: Members Posts: 2,283 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
We have several good discussion topics already going on this.
The Dub Shop (Mario's a super guy) has a bolt-on system. But I think he's having difficulties getting throttle bodies: https://thedubshop.com/dual-throttle-body-f...gnition-t4-914/ Here's a guide I wrote on my Microsquirt conversion of D-Jet (it's not a quick read*): https://tgadrivel.blogspot.com/2020/03/on-m...914-part-1.html Search the site and you'll find other projects with Megasquirt and Haltech. - GA *I did it that way mostly for myself, to remind me WiTH I did and how I got there. But I figure that if you don't have the patience to read through the thing theny ou probably don't have patience to build it... (IMG:style_emoticons/default/wink.gif) |
scott_in_nh |
Feb 8 2023, 04:37 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
We have several good discussion topics already going on this. The Dub Shop (Mario's a super guy) has a bolt-on system. But I think he's having difficulties getting throttle bodies: https://thedubshop.com/dual-throttle-body-f...gnition-t4-914/ Here's a guide I wrote on my Microsquirt conversion of D-Jet (it's not a quick read*): https://tgadrivel.blogspot.com/2020/03/on-m...914-part-1.html Search the site and you'll find other projects with Megasquirt and Haltech. - GA *I did it that way mostly for myself, to remind me WiTH I did and how I got there. But I figure that if you don't have the patience to read through the thing theny ou probably don't have patience to build it... (IMG:style_emoticons/default/wink.gif) @GregAmy That was a good read - thanks for taking the time to put it together! So let me ask you this: Let's say you already have a 123 distributor with the FI points that you are happy with - could you use one or both of the triggers as a cam/crank position sensor with Microsquirt? The obvious benefit being that you do not have to take the engine out to to fit a trigger wheel (or to change a bad sensor). If possible I think it might really simplify the changeover to Microsquirt and a lot of guys already have them installed..... Scott |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:46 AM |
