Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
GregAmy |
Mar 24 2023, 08:55 PM
Advanced Member Group: Members Posts: 2,283 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
That’s wild. Had to have been done in the late 90s by a heavy duty Hondata guy or something. I can’t imagine ever doing something so complicated in the 2000s when MS and a lot of other budget EFI systems really started taking off. Yep, I'm thinking it's a much older build because he says there's no external USB port on the ECU. That indicates it's a socketed EEPROM, well before the Hondata S300 era, so probably late 90s/early 00s. Probably Moates. I just think it's pretty damned cool that someone went to all that trouble to engineer a D-Jet install to use the (probably) Moates-programmable Honda ECU. I guess when you think about that era, that was about as good as it was for tuneable ECUs...hell, I was doing it with Nissan back then (early 00s) and I thought I was the s**t...that's old school classic rocker stuff; we're not worthy... - GA |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:14 PM |
