Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
r_towle |
Mar 25 2023, 09:16 AM
Custom Member Group: Members Posts: 24,571 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Back about 15,years ago, I tuned a 2.4 liter to 150 hp, dyno tested at the wheels. I used stock djet.
It turned into a big argument with a certain aircooled engine “expert” who falsely claimed it could never be done. It can be done. The MPS and the right resistor in the CHT circuit, along with an 02 sensor to measure results is what is required. We used a dyno at the end to see how close we got…. But most of the tuning was up and down my street. Djet runs rich, and can made much richer if required. After I learned the two basic things to tune, I got almost 50 mpg from a 1.7…. Djet was also used on Volvos and a few others. I ended up trying all the MPs units from those, we settled back on the 914 one and learned how to tune it. Best way is with an 02 sensor stuffed up the tail pipe. I own the djet tester, but it is just a break fix tool. If I was going to do it again I would use the inline exhaust sensors Foley came up with to measure each exhaust port. Rich |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:03 AM |
