Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
targa72e |
Mar 25 2023, 10:24 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
Not quite 914 FI related but Porsche related. I replaced the CIS on my 78 911 SC with a later 3.2 Carrera manifold and injectors using the injection system from a Nissan 280ZX. I tweeked the barn door AFM and coolant temp sensor to tune the fuel mixture. It worked well. This was in the early 90's with limited affordable aftermarket ECU's. Worked good for years. I eventually replaced it with a FAST programmable system designed for Chevy's. That FAST system from the 90's and the Carrera intake is still running on my friends 911 today.
john |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:12 PM |
