Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
Geezer914 |
Mar 27 2023, 09:31 AM
Geezer914 Group: Members Posts: 1,393 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Search for a used Ljet system. You can adjust the AFM with the wheel inside.
ClayPerrine |
Mar 27 2023, 10:57 AM
Life's been good to me so far..... Group: Admin Posts: 15,430 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Search for a used Ljet system. You can adjust the AFM with the wheel inside. L-Jet is a good system. But it has some limitations that modern EFI doesn't. L-Jet cannot handle any kind of radical camshaft. The flap in the airflow meter starts oscillating badly due to the cam overlap, and that is detrimental to proper mixture control, and makes the air flow meter wear out rapidly. That's one of the big reasons that Porsche went from a vane air meter in the 964( like the L-Jet has) to a Mass airflow sensor in the 993. And that's the reason I am going away from the 964 motronic in my car. I have a huge, unresolvable flat spot off idle due to the vane air meter oscillation. I could have gone to a 993 motronic, but the Megasquirt MS3Pro is actually cheaper and gives me more control over the engine. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:54 AM |
