Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have? |
DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
jd74914 |
Mar 28 2023, 01:31 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
In tank is the way to go if you can make it work. Pump stays cool all of the time and you remove an out of tank leak point. My favorite setups for normal engines also have the regulator integrated so you don’t need that external either.
With the ITBs you really need to use timing to control idle…IMO at least. |
ClayPerrine |
Mar 28 2023, 05:04 AM
Life's been good to me so far..... Group: Admin Posts: 15,430 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
In tank is the way to go if you can make it work. Pump stays cool all of the time and you remove an out of tank leak point. My favorite setups for normal engines also have the regulator integrated so you don’t need that external either. With the ITBs you really need to use timing to control idle…IMO at least. A lot of the aftermarket injection systems are now running no fuel pressure regulator. Instead, they use a fuel pressure sensor, a solid state relay and pulse width modulation of the fuel pump circuit to regulate the pressure. So no pressure regulator and no return line. The ECU controls the fuel pressure and can increase and decrease it as needed for best efficiency. I am installing a stepper IAC On my ITB setup. The timing changes can only do so much for the idle control. Think of it as the IAC controls the major idle speed changes. Timing fine tunes it. |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:49 AM |
