| Boothy |
Feb 7 2023, 10:05 AM
Member ![]() ![]() Group: Members Posts: 108 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Morning all!
I have a 1972 914 with a 1.7 (with mods). I sent the crank out to Fat Performance / Rimco for balancing a couple years ago (seem to be gone now). All that was fine but it didn’t come back with the single dowel that indexs the crankshaft to the flywheel. I thought I bought the right one from AutoAtlanta but it doesn’t want to go into the end of the crankshaft (and I don’t want to force it). I bought the 900-012-061-00 but I now see that’s for the 914-6. Would anyone know the correct part number? Thanks! |
| bdstone914 |
Feb 7 2023, 10:16 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I dont know the part number but i think it is a 4mm roll pin. Measure the hole size to confirm. You can probably find one locally or from Bel Metric.
| Al Meredith |
Feb 7 2023, 10:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 984 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I've got several bad cranks and if I can get one out I'll be glad to send it to you. Al
| 914werke |
Feb 7 2023, 10:39 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,679 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Part # 113 105 277
| Boothy |
Feb 7 2023, 10:46 AM
Thank you all!!!
I'll try that one instead. Best! |
| barefoot |
Feb 8 2023, 08:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,517 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Pin is not really needed, it just insures you can't install flywheel timed wrong.
Without pin, just make sure you time it correctly. It adds nothing to structural integrity. |
| rhodyguy |
Feb 8 2023, 08:13 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Don’t forget a new bearing for the trans input shaft, while you’re in there, and set it to the correct depth. Seldom mentioned.
| Boothy |
Feb 8 2023, 12:56 PM
Will do. I don't want to pull it for a very very long time -if ever.
Thank you! |
Lo-Fi Version | Time is now: 8th June 2026 - 04:23 PM |
