Boothy |
Member ![]() ![]() Group: Members Posts: 108 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States ![]() |
Morning all!
I have a 1972 914 with a 1.7 (with mods). I sent the crank out to Fat Performance / Rimco for balancing a couple years ago (seem to be gone now). All that was fine but it didn’t come back with the single dowel that indexs the crankshaft to the flywheel. I thought I bought the right one from AutoAtlanta but it doesn’t want to go into the end of the crankshaft (and I don’t want to force it). I bought the 900-012-061-00 but I now see that’s for the 914-6. Would anyone know the correct part number? Thanks! |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,028 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I dont know the part number but i think it is a 4mm roll pin. Measure the hole size to confirm. You can probably find one locally or from Bel Metric.
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 973 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
I've got several bad cranks and if I can get one out I'll be glad to send it to you. Al
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,293 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Part # 113 105 277
Boothy |
Thank you all!!!
I'll try that one instead. Best! |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,410 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Pin is not really needed, it just insures you can't install flywheel timed wrong.
Without pin, just make sure you time it correctly. It adds nothing to structural integrity. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Don’t forget a new bearing for the trans input shaft, while you’re in there, and set it to the correct depth. Seldom mentioned.
Boothy |
Will do. I don't want to pull it for a very very long time -if ever.
Thank you! |
Lo-Fi Version | Time is now: 5th July 2025 - 03:04 PM |
