Trailer tires, Time to replace. Suggestions |
Krieger |
Feb 7 2023, 06:51 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
So my twin axle 7000 lb. open trailer is 8 years old and the date code on these tires will be 9 years soon. I know I must replace these tires. I completed inspected each tire every time I used the trailer. Maybe around 6-7k miles total. The tires look like they are maybe three years old. I think these were bias ply. They are Hi Run LQ 229 205/75 D 15. I just found these online for $69 each. For all I know Hi Run are crap tires now. Should I just go to COSTCO or Les Schwab? Does anybody have brand recommendations? Radial or bias ply?
Thank you Attached thumbnail(s) |
brant |
Feb 7 2023, 08:27 PM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
You really need trailer rated tires
I believe decent ones are 10 ply You really don’t want a problem when towing That could take out your tow vehicle at the same time Worth correct trailer tires |
Jamie |
Feb 8 2023, 09:03 AM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
You really need trailer rated tires I believe decent ones are 10 ply You really don’t want a problem when towing That could take out your tow vehicle at the same time Worth correct trailer tires It is definitely poor policy to cheap out on trailer tires. I have many years experience towing big RV's as well as smaller trailers, and always rely on the reduced heat build-up characteristics and flexibility of radial tires rated for trailer use. They are formulated for less degradation from constant UV exposure, but still need to be constantly inspected and replaced on recommended schedule. |
Lo-Fi Version | Time is now: 6th May 2024 - 11:12 AM |
