Trailer tires, Time to replace. Suggestions |
Krieger |
Feb 7 2023, 06:51 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
So my twin axle 7000 lb. open trailer is 8 years old and the date code on these tires will be 9 years soon. I know I must replace these tires. I completed inspected each tire every time I used the trailer. Maybe around 6-7k miles total. The tires look like they are maybe three years old. I think these were bias ply. They are Hi Run LQ 229 205/75 D 15. I just found these online for $69 each. For all I know Hi Run are crap tires now. Should I just go to COSTCO or Les Schwab? Does anybody have brand recommendations? Radial or bias ply?
Thank you Attached thumbnail(s) |
slivel |
Apr 5 2024, 12:09 PM
Old car....... older driver Group: Members Posts: 508 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
Having towed race car and horse trailers for more than 24 years, I am a believer in quality trailer rated tires that are sized for your load. Load range D (65 psi) or load range E (80 psi) are what I use. Additionally, I strongly recommend a TPMS system for your rig. A slow leak will heat up the tire and eventually cause failure. TPMS saved me more than once. They are not terribly expensive and I put sensors on the tow vehicle and the trailer. https://www.amazon.com/Truck-Systems-Techno...ressure-Monitor Sorry, I truncated the link and it doesn't work. Just search for tire pressure monitoring systems. |
Lo-Fi Version | Time is now: 6th May 2024 - 06:43 PM |
