16 X 7 Fuchs clone wheel fitment question |
technicalninja |
Feb 7 2023, 10:14 PM
Senior Member Group: Members Posts: 1,194 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
New member here...
I'm piss poor at the search function on this site and was trying to find fitment info on this set up. https://fuchswheelcompany.ca/product/16x7-f...eel-for-porshe/ They list it a 16X7 with an offset of 23.3. From what I have found so far, they look like they might require 12 mm spacers to work on a stock 75 914 narrow body. This car will be at or near stock ride height and a weekend play toy. It currently has no sway bars but that will probably change... I'm planning on using PBR's 5 lug 914-4 front rotors, the Uro 914 5 lug rear flange with turned down PBR 914-6 rear rotors, and stock calipers. I'd like to use this tire. (205/60r16) https://www.tirerack.com/tires/TireSearchRe...performance=ALL I'm new to the 914 and can't figure offsets properly yet on this chassis I would appreciate thoughts, tips and any suggestions. Do I have a chance? |
tygaboy |
Feb 7 2023, 11:00 PM
914 Guru Group: Members Posts: 5,287 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
7s are a "maybe" on the rear of a narrow body - it depends on your chassis. On mine, I had a teeeeeeny bit of clearance on one side and not enough on the other. Forget spacers as you're likely looking at having to roll your fenders.
YMMV. Oh, and (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 8th May 2024 - 06:31 PM |
