16 X 7 Fuchs clone wheel fitment question |
technicalninja |
Feb 7 2023, 10:14 PM
Senior Member Group: Members Posts: 1,191 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
New member here...
I'm piss poor at the search function on this site and was trying to find fitment info on this set up. https://fuchswheelcompany.ca/product/16x7-f...eel-for-porshe/ They list it a 16X7 with an offset of 23.3. From what I have found so far, they look like they might require 12 mm spacers to work on a stock 75 914 narrow body. This car will be at or near stock ride height and a weekend play toy. It currently has no sway bars but that will probably change... I'm planning on using PBR's 5 lug 914-4 front rotors, the Uro 914 5 lug rear flange with turned down PBR 914-6 rear rotors, and stock calipers. I'd like to use this tire. (205/60r16) https://www.tirerack.com/tires/TireSearchRe...performance=ALL I'm new to the 914 and can't figure offsets properly yet on this chassis I would appreciate thoughts, tips and any suggestions. Do I have a chance? |
dr914@autoatlanta.com |
Feb 8 2023, 10:30 AM
914 Guru Group: Members Posts: 7,838 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
7x16 will fit stock fender wells with the correct wheel offset. Our man Albert is well connected with the Fuchs, Maxilite and Braid wheel factories so can custom order wheels that fit correctly
Lo-Fi Version | Time is now: 7th May 2024 - 10:31 PM |
