16 X 7 Fuchs clone wheel fitment question |
technicalninja |
Feb 7 2023, 10:14 PM
Senior Member Group: Members Posts: 1,192 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
New member here...
I'm piss poor at the search function on this site and was trying to find fitment info on this set up. https://fuchswheelcompany.ca/product/16x7-f...eel-for-porshe/ They list it a 16X7 with an offset of 23.3. From what I have found so far, they look like they might require 12 mm spacers to work on a stock 75 914 narrow body. This car will be at or near stock ride height and a weekend play toy. It currently has no sway bars but that will probably change... I'm planning on using PBR's 5 lug 914-4 front rotors, the Uro 914 5 lug rear flange with turned down PBR 914-6 rear rotors, and stock calipers. I'd like to use this tire. (205/60r16) https://www.tirerack.com/tires/TireSearchRe...performance=ALL I'm new to the 914 and can't figure offsets properly yet on this chassis I would appreciate thoughts, tips and any suggestions. Do I have a chance? |
Root_Werks |
Feb 9 2023, 01:33 PM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Also believe if you can locate 16x7 951 fuchs, it pulls the offset in just enough rolling the rear fender isn't required.
I think anyway.... |
sixnotfour |
Feb 9 2023, 04:57 PM
914 Wizard Group: Members Posts: 10,423 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
mepstein |
Feb 9 2023, 05:25 PM
914-6 GT in waiting Group: Members Posts: 19,257 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Also believe if you can locate 16x7 951 fuchs, it pulls the offset in just enough rolling the rear fender isn't required. I think anyway.... same offset , they have added caliper Clearnce.. It's the 951 8" wheels that are different offset from the 911 8" wheels. Let's you put an 8" wheel on the front of a 911 and use a 9" on the back. Normally, a 911 8" wheel will rub the front fender of a 911. |
Lo-Fi Version | Time is now: 8th May 2024 - 04:55 PM |
