Relay board bad connector |
seanpaulmc |
Feb 8 2023, 05:28 PM
Member Group: Members Posts: 297 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Has anyone had success fixing a bad contact (male spade) on the 914's relay board?
Hats off to you folks that clean and refurbish these boards for others. (IMG:style_emoticons/default/pray.gif) I have a lot of hours in cleaning up this board and with finding this bad connector (material loss) I'd prefer to fix it and move forward rather than finding another board and starting over. I've done continuity checking on everything and the board is in good shape and cleaned up relatively well otherwise. I suspect these spade connectors can be un-soldered and pushed out the back. Can anyone verify that? And where to get a duplicate replacement piece? And, after some judicious cleaning... Odd that it's only one of the four that is bad. As always, thanks in advance. -Sean |
Superhawk996 |
Feb 9 2023, 08:39 AM
914 Guru Group: Members Posts: 5,761 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If you’re really worried about it, desolder the old terminal from the bottom. Use a solder sucker and copper braid to remove all traces of solder. Find appropriate male spade terminal - modify to fit board. Solder back to the trace.
Lo-Fi Version | Time is now: 29th April 2024 - 12:18 PM |
